Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th December 2004, 03:24 PM   #1
Default Wiring drivers
I have 4 mids-tweeters;4x4Ohm and stereo amp with 4-8ohm support.Will be sensitivity 3db higher per a pair if I wire them pararell and add 2ohm resisitor(ceramic,powerful)?
-Sensitivty is usualy 3db higher if there are drivers wired pararell,but Im worried,that the resistors can smooth 3d down
Dean
Extremely silly question about wiring 4 drivers Cloth Ears Subwoofers 4 4th September 2008 10:10 AM
Series-wiring drivers instead of parallel, how does the Xover change? Glowbug Multi-Way 1 16th January 2007 04:46 AM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 04:37 AM
Multiple Drivers - Series and Parallel Wiring ralph-bway Multi-Way 1 17th February 2004 03:38 PM
Page generated in 0.05390 seconds (65.54% PHP - 34.46% MySQL) with 10 queries
