| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am designing an amp that will run off of +/-75v rails. I want to use MOSFETs for the outputs, but I don't know much about them. How much voltage do I need at the gates to get the FETs to swing from rail to rail (or close to the rails)?
#2 |
Depends on the configuration and the devices. If they are in common-source configuration then it's easy to get them to swing to the rails with Vgs of maybe 5-10V or so, limited only by the on resistance. If they're configured as source-follower then you will probably need to take the gate voltage a couple of volts above the rails to get maximum swing, also limited by on resistance.
https://mrevil.asvachin.eu/ |
#3 |
What's the difference between common-source and source-follower?
#4 |
Did it Himself
Common source = CFP (complementary feedback pair / Sziklai pair), n-ch device in lower half and p-ch device in upper half.
Source follower, n-ch device in upper half and p-ch device in lower half. |
#5 |
Attached is the amp I am working on. I need some help chosing output FETs. Which ones would be good? Would it be better to use N-channel on both rails? If so, how would I go about modifying this circuit to use all N-ch output FETs?
#6 |
That's a really small amp...microscopic. in fact.
#7 |
Thanks for pointing that out. I haven't realized that I didn't attach it.
#8 |
I don't follow the workings of this schematic. It seems unconventional to me. Comments anyone?? Try looking up previous threads here for suitable versions, there are a couple running just now in solid state. regards Andrew T. |
#9 |
Did it Himself
I've seen this kind of thing before, it's not common. Common base topology may be a way to describe it. It may be similar to Jan Dupont's (ACD) Lynx amp.
The output stage consisting of Q3,4 M1,2 is wrong as there's no method of biasing the output devices. R4 is doing nothing. If it makes it look OK in simulation that's because the output stage is incorrectly set up in the first place. |
#10 |
All this schematic is uncorrect, please read something about design of amps - I recomend to you for example pages of Erno Borberly
| Series MOSFET regulator better with just voltage ref on gate or with error amp? | ray_moth | Tubes / Valves | 69 | 20th May 2011 01:35 AM |
| mosfet gate voltage question | carpenter | Pass Labs | 6 | 22nd July 2009 02:34 AM |
| Do I have to match voltage Gate-Source of mosfet in SMPS? | Charoenchai | Car Audio | 5 | 17th November 2006 09:28 PM |
| Where to buy a low gate voltage p channel MOSFET or make an alternative? | Corn-Picker | Everything Else | 6 | 16th December 2003 10:15 PM |
| mosfet gate charge | Diogo | Solid State | 12 | 19th August 2002 12:24 PM |
| Page generated in 0.10088 seconds (76.35% PHP - 23.65% MySQL) with 11 queries |
