Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
MOSFET gate voltage
MOSFET gate voltage
Old 3rd December 2004, 09:47 AM   #11
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
MOSFET gate voltage
Default Re: MOSFET gate voltage
Originally posted by xplod1236
I am designing an amp that will run off of +/-75v rails. I want to use MOSFETs for the outputs, but I don't know much about them. How much voltage do I need at the gates to get the FETs to swing from rail to rail (or close to the rails)?
I'm afraid that Upupa is right. You must get basic knowledge first because your efforts so far is totally wrong, sorry.
You can find some inspiration at Rod Elliot
http://sound.westhost.com/
Anthony Holton
http://www.aussieamplifiers.com/
http://www.borbelyaudio.com/
http://homepages.strath.ac.uk/~cnbp111/amp1.html
http://www.analog.com/UploadedFiles/...17334AN211.pdf
http://mirand.dk/
http://users.ece.gatech.edu/~mleach/lowtim/
http://www.astro.uu.se/~marcus/private/m250.html
http://www.ne.jp/asahi/evo/amp/
And many many more.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 48 pcb's in order. 19 paid.
Old 3rd December 2004, 10:46 AM   #12
xplod1236 is offline xplod1236  United States
xplod1236's Avatar
Send a message via AIM to xplod1236
That is a modified schematic from national. R4 is there to take take out crossover distortion. The opamp compensates for the outputs not being biased.
I ran this in a simulator, and it seems to be working fine.
Old 3rd December 2004, 10:53 AM   #13
peranders's Avatar
MOSFET gate voltage
You are forgetting about temp and bias stability issues. The parts you are using are indentical and at the same temp and this is not the case in real life.
Why don't you test your circuit in real life?
Do you have any reference from National where we can find more info?
Old 3rd December 2004, 11:46 AM   #14
Mr Evil is offline Mr Evil  United Kingdom
The circuit isn't completly wrong, it will work. Because the voltage swing required from the op-amp is very small, and the common base stage is very fast, crossover distortion can be quite low even with no bias. I have built similar output stages before and they work nicely. You have to be careful of stability though, since it has a high voltage gain.
As for your questions: It's better to stick with complementary pairs since the symmetry will tend to be better rather than fudging one half of the output stage. Personally, my favourite MOSFETs are those from Exicon. They're quite linear, very robust,not too expensive and helpfully have a low Vgs threshold.
https://mrevil.asvachin.eu/
Old 3rd December 2004, 06:48 PM   #15
xplod1236's Avatar
http://www.national.com/an/AN/AN-272.pdf page 4 and 5 (+/- 120v swing booster). I would've posted that this morning, but I did not have time to find the link.
The gain is only 10x, so would I still have problems with it?
This is for a sub amp, so a little bit of crossover distortion that's not audiable would be fine.
Old 4th December 2004, 12:45 PM   #16
...The gain is only 10x, so would I still have problems with it?..
I mean the output stage has a high open-loop gain. That means that the overall gain could be greater than 1 when the phase shift exceeds 180 degrees, and the amp will oscillate.
The 100pF feedback around the op-amp will help with that, but whether or not it is enough may depend on what devices you choose for the output stage. Make sure to simulate it thoroughly.
I was wondering if you really need Q3/Q4 at all. You could probably get away with putting the MOSFETs where Q3/Q4 are now. That would make it much easier for you to get rail-to-rail output swing.
Old 4th December 2004, 03:16 PM   #17
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
You know, looking at your schematics, you could easily copy something like the Soundcraftsmen circuit design, or just about any commercially available amp for that matter. the parts count would be about the same and you have a proven design that works with the added benifit of the circuit being very clean!
I think your working way too hard to achieve the same goal.
Zero
Old 4th December 2004, 03:23 PM   #18
Zero Cool's Avatar
For example, check out the schematics found on the exicon website for there demo boards.
There is some great information here about the design as well.
http://www.profusionplc.com/static/images/data%20sheets/apnotes.pdf
Zero
MOSFET gate voltageHide this!Advertise here!
Series MOSFET regulator better with just voltage ref on gate or with error amp? ray_moth Tubes / Valves 69 20th May 2011 01:35 AM
mosfet gate voltage question carpenter Pass Labs 6 22nd July 2009 02:34 AM
Do I have to match voltage Gate-Source of mosfet in SMPS? Charoenchai Car Audio 5 17th November 2006 09:28 PM
Where to buy a low gate voltage p channel MOSFET or make an alternative? Corn-Picker Everything Else 6 16th December 2003 10:15 PM
mosfet gate charge Diogo Solid State 12 19th August 2002 12:24 PM
