Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th November 2004, 11:03 PM   #1
Sanaka's Avatar
Default Is there a simple capacitor matching method?
Is there a simple circuit/setup one can build that will match pairs of capacitors?
I'm thinking something where you clip in two caps, and if they are a reasonable match, say a couple percent or so, a light goes on or goes off or some indicator is activated. Relative matching rather than absolute value being the important criterion, and 1uf to 1000uf being the important range.
The reason is so that signal path caps that impact frequency response/bass rolloff are pretty close for L/R stereo channels.
Thanks!
Peace,
Sanaka
Old 30th November 2004, 11:38 PM   #2
johnnyx is offline johnnyx  United Kingdom
Put the caps in the arms of an ac driven bridge circuit, like a Wheatstone bridge, so that when the caps are the same the output to a meter is a minimum.I'll try to attach a diagram to explain it.
Old 1st December 2004, 12:03 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
It'll be friendlier if you swap R1 and C2, although you'll need a real low frequency for large values (like PSU caps) anyway.
In either case, when R1=R2 and C1=C2, the meter will show no current (i.e., balance).
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 1st December 2004, 02:36 AM   #4
Stocker is offline Stocker  United States
If all you want to do is MATCH capacitors...
There is a circuit available online though I have yet to build it, called IIRC the C-beeper or e-beeper or some such. the most exotic part is a variable capacitor that shouldn't be too hard to get. The point of the device is that there is a sound produced when a capacitance is connected to the case as you hold the other end of the capacitor. The sound is supposed to vary drastically with changes in capacitance, so matching becomes a VERY fast and easy excercise. The actual value of the caps is completely irrelevant to the device, other than changing the capacitance slightly changes pitch of audio output.
I intend to build one of these after I build a multimeter that is mostly done, and maybe before a good variable oscillator...but I will build one. If you google and can't find it (and want to) I will try to dig it up for you.
Jesus loves you.
Old 1st December 2004, 06:26 AM   #5
Sanaka's Avatar
Thanks johnnyx and schematic,
That's pretty much perfect I had run across "Wheatstone bridge" but all the info I saw was for resistors and strain gauges. In your circuit johnnyx, would a plain cheapo 5v or 9v wall wart suffice for the AC driver?
Stocker: I meant to mention that I had seen the Curious C-beeper. It's a way cool concept, but optimized for small, like <1uf, caps. Plus more complicated than I need right now.
Peace,
Sanaka
Old 1st December 2004, 04:13 PM   #6
A wall wart would be ok, 50Hz (or 60Hz in USA) would be fine for the larger caps found in crossovers. Btw, the resistors can be reduced from the value shown - 10k is just the default value given by the drawing program. You could elaborate it a bit and work out some way of determining when the caps are within say 1% of balance, otherwise you could be there for ever trying to find two identical ones.
Old 1st December 2004, 11:34 PM   #7
Now all you need is a set of matched resistors!
I have some high-precision (unmatched as yet) wirewound 10Ks though... Hmmmm...
Jesus loves you.
Old 3rd December 2004, 07:33 AM   #8
make one of the resistors variable with a pointer and scale.
Adjust the pot to achieve balance and note each reading on the caps. Quite soon you will have some that are quite close, then you can be more precise.
regards Andrew T.
Old 7th December 2004, 04:48 AM   #9
Many cheap DMMs have capacitance measurement facility
Gajanan Phadte
Old 8th December 2004, 05:59 AM   #10
Many of us do not want to purchase additional DMMs!
The cost to quite a few of us will be $0 for this type of project.
I just did 3 measurements. I now have 2 N.I.S.T. traceably matched resistors (0.00x% variance ) and one that's within 0.02%. Now for a little transformer...
5-digit ohmmeter at work does a good job of measuring 10k's to the ohm!
Jesus loves you.
Simple SE aux capacitor hartze11 Tubes / Valves 8 10th June 2009 08:26 PM
Comments on this matching method?? Zero Cool Solid State 11 7th May 2008 08:55 AM
Simple Method To Measure Source Resistance? kelticwizard Tubes / Valves 21 27th December 2005 05:49 AM
simple matching philosophy on tubes.. GeirW Tubes / Valves 1 17th February 2004 07:20 AM
simple capacitor-less amp xocoatl Solid State 0 23rd April 2003 11:56 AM
Page generated in 0.10661 seconds (79.03% PHP - 20.97% MySQL) with 11 queries
