Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th November 2004, 09:27 AM   #1
klitgt is offline klitgt  Denmark
klitgt's Avatar
Default Confused with diodes
What is the difference between schottkey and fast recovery diodes?
Some say you should use shottkeys in PSUs for audio (preamps, DACs etc), others say fast recovery diodes. Is it the same thing?
What is the advantage of the above diodes vs. common rectifying diodes like e.g. 1n4001?
Old 30th November 2004, 11:11 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
Schottky diodes are made of silicone and aluminium and they are extemely fast and have also a very low voltage drop which is good if you want to keep the losses low in especially switched mode power supplies at low voltaged like 5 volts or so.
Drawback: Can't handle very high voltage, expensive, can't handle huge currents
Fast recovery diodes are plain P-N silicone diodes with higher (or "normal") voltage drop.
For 50-60 Hz applications it's normally overkill to use fast diodes but not if you are an audiophile. Even I have used those in my latest Gainclone but I can't verify how much good the do.
For 50kHz- 1MHz applications choosing the right diode is the difference between success and failure!
/Per-Anders (my first name) or P-A as my friends call me
Confused about DVC and Q mashaffer Multi-Way 13 30th July 2006 03:40 PM
confused gtrtech Solid State 7 28th August 2005 06:22 AM
Confused! alieas_neo Car Audio 2 1st May 2004 06:45 PM
I'm Confused and I need your help. Paprika Solid State 12 22nd September 2003 07:49 AM
Page generated in 0.06531 seconds (68.65% PHP - 31.35% MySQL) with 10 queries
