| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Anyone knows how AC solid state relays get along with dc??
The load that is. Cheers Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#2 |
Most of the AC solid state relays use a triac as a switch. Triacs only turn off when the current through them goes to zero, which generally happens twice in every AC cycle. So if you put DC through it you can turn it on, but not off!
#3 |
So basicly a solid state relay is a thyristor with an optocoupler??
Cheers Magura
#4 | |
#5 |
That depends on how fancy the relay is. Not all have zero-crossing turn-on circuits.
#6 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#7 |
I am thinking about using SS relays for switching between one secondary and both secondaries in series in a 20A 25/50V power amp.
Maybe the simple solution would be to do this before the rectifiers to avoid DC?? I just have doubt that the boards from the previous groupbut can take such current. Magura
#8 |
How are they for reliability? I’m thinking of using something like the pass labs A75 schematic to turn on and off an amp. It uses a triac. An other option is to use a real relay, they cost about the same. However I do done always trust semiconductors. Anybody got any opinions?
#9 | |
What diodes are you using and how much capacitance do you have and also what is your supply voltage? Notice also that if you really have such problems a soft starter at the primary is better, smaller currents.
#10 |
Hmm, better explanation of the application required.
The point is to be able to switch between 25 and 50V for a Zen V7. RURG3020 diodes, 200.000uF, 1KVA trafo 2*18V. The alternative is a hefty contactor, but those tend to wear out and they are huge compared to a SS relay. Magura
| solid state relays for switched attenuator | nobody special | Solid State | 19 | 1st February 2006 10:41 AM |
| state of the art relays | Berki | Parts | 63 | 29th October 2004 02:33 AM |
| The Solid State Wiki - Your solid state reference guide | Jason | Solid State | 0 | 25th June 2002 05:26 PM |
| Page generated in 0.09928 seconds (81.72% PHP - 18.28% MySQL) with 10 queries |
