Solid state relays??? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th November 2004, 03:33 PM   #11
Electrons are yellow and more is better!
peranders's Avatar
How often should you change the voltage and why? How much current does the amp consume?
Your diodes can take 325 A non-repetitive and 70 A repetitive.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 110 paid.
Old 29th November 2004, 03:36 PM   #12
Magura is offline Magura  Denmark
Magura's Avatar
It might happen pretty often. The reason to switch voltage is to save power for background listening at 20W music power, while having the option to get a lot of power for higher volume/ critical listening with 50W. This can be achieved by switching the voltage.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 29th November 2004, 03:39 PM   #13
peranders's Avatar
Can't you solve this with two transformers. Put the 230 V primary windings in series or in parallel. I assume that you don't need to switch when the power is switched on?
I think you can forget a solid state relay but I think it's quite possible to solve this with a couple of bauta mosfets.
Old 29th November 2004, 03:46 PM   #14
Magura's Avatar
Well, part of the trick would be the ability to switch while powered. The caps should be adequately big to supply 0.2sec. of power and let it run seamless.
I guess it would be worth mentioning that I use a PLC for the control of the amp.
The end solution just might be to build a more powerfull bridge and switch the secondaries before the rectifier.
I guess 2 bridges in parallel is a bad idea??
Magura
Old 29th November 2004, 03:52 PM   #15
peranders's Avatar
That is a good idea and them switching between two transformers.
Old 29th November 2004, 03:53 PM   #16
Magura's Avatar
Thanks, problem solved.
Magura
solid state relays for switched attenuator nobody special Solid State 19 1st February 2006 11:41 AM
state of the art relays Berki Parts 63 29th October 2004 03:33 AM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 06:26 PM
Copyright ©1999-2017 diyAudio
