diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   Source for cheap caps >10000uF, 80V ? (http://www.diyaudio.com/forums/parts/46217-source-cheap-caps-10000uf-80v.html)
Freddie 21st November 2004 04:06 PM
Hi
Do you know a source for "cheap" electrolytic capacitors, >=10000uF 80V ?
(So far the chepeast I found is 8.353 Euro + VAT, www.profusionplc.com)
regards
/Freddie
AndrewT 22nd November 2004 07:17 AM
Hi, there is a supplier in the US that sells thro' ebay doing very good prices on larger quantities. I did not bid just went straight to buy it now - much cheaper than UK. Service was excellent
I got 1.3million uF at 63v to 80v including 150,000uF Hi frequency for under 200gbp
regards Andrew T.
Nisbeth 22nd November 2004 07:18 AM
http://www.neuhold-elektronik.at/cat...roducts_id=249
10000uF/80V 2,9 EUR each (2,6 EUR each in quantities above 5). These are Nichicon LQ-series caps, IIRC farnell has the datasheet (do a search for LQ on their website)
/U.
EDIT: Andrew might be referring to this link: http://stores.ebay.com/JEA-Capacitors
Copyright 1999-2017 diyAudio
