Self etched PCBs: what trace width and spacing should I use? - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st November 2004, 02:06 PM   #11
Keep any spacings between hi voltage and signal lines at least 4 mm. This means between anything over 40V peak and signal or ground level.
This is a UL standard for safety spacings.
I do 15 mil tracks all the time on home made boards.
Old 21st November 2004, 02:08 PM   #12
Bricolo is offline Bricolo  France
Bricolo's Avatar
it's not for high voltage
ps will be +-15V, and signals aroung 2V rms
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 21st November 2004, 02:16 PM   #13
Bricolo's Avatar
Does this look acceptable?
Spacing is eagle's default setting (8mil), but I changed the trace width to 1mm
http://roulz.free.fr/DIY/board.pdf
Old 21st November 2004, 02:19 PM   #14
pinkmouse's Avatar
I'd leave a bit more spacing than that, otherwise soldering will be a real pain...
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 21st November 2004, 02:35 PM   #15
Bricolo's Avatar
OK.
For soldering, so just arounf the pads, or also for the tracks?
This spacing allows me to have a full groundplane, going nearly everywhere since it even goes between the pads.
Are the traces ok, or too thick?
Old 21st November 2004, 03:56 PM   #16
Bricolo's Avatar
Here are 2 others:
http://roulz.free.fr/DIY/board-12.pdf (12mm spacing)
http://roulz.free.fr/DIY/board-16.pdf (16mm spacing)
Old 21st November 2004, 05:37 PM   #17
acenovelty's Avatar
HP4 Laser will print very cleanly down to 1/64 inch, both trace and spacing (.3969mm for the rest of the world.)
Prosit
Two people can keep a secret if one of them is dead.
Old 21st November 2004, 06:54 PM   #18
Bricolo's Avatar
So, only down to 16mil??
I printed the first pdf (8mil) on my canon bubble jet, on a sheet of paper
and the result is ok (except at one 45° trace)
so a laser printer on a transparency will do better, I think
Old 21st November 2004, 07:10 PM   #19
Electrons are yellow and more is better!
peranders's Avatar
I have made pcb's with 13 mil traces but this is something you must test yourself. I have made pcb's with traces between IC pins.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 21st November 2004, 08:10 PM   #20
Bricolo's Avatar
13mil? That seems small
what's a reasonable width for line level audio signal?
FS: Aleph-X PCBs , NIGC PCBs , OPA541AM OpAmps e.lectronick Swap Meet 25 6th March 2013 07:40 PM
DIY soldermask for home-etched PCBs DJ Exprice Parts 2 20th May 2006 04:37 PM
PCB Trace Width Current rating?? Zero Cool Everything Else 9 21st November 2004 07:48 PM
Any interest in laser etched/cut Lucite front panels? laserit Swap Meet 12 29th April 2004 12:49 PM
hey guys, i have a 50watt co2 laser in my garage. need anything etched? travis Everything Else 13 14th July 2003 03:32 PM
Copyright ©1999-2017 diyAudio
