Sound like a dc offset problem. I built this for myself:
http://home.swipnet.se/~w-50719/hifi/dct01/index.html
Here's a few pics of my unfinished filter (the module on the left is 1. stage filter)
http://kotiweb.kotiportti.fi/audiovideo/download/valmiit moduulit.jpg
http://www.hifilehti.fi/keskustelu/upfiles/41/Ec894480878.jpg
Check out these threads:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=37942&perpage=20&highlight=&pagenumber=1
http://www.diyaudio.com/forums/showthread.php?s=&threadid=2080&perpage=20&highlight=&pagenumber=4
Those are filters are bad. They will probably restrict dynamics. You might wan't to read this article:
http://www.geocities.com/jonrisch/surge.htm
If you wan't to get rid of humming, try this (it tells all the tricks in the world):
http://www.psaudio.com/account/humbusters.asp
(you need to register to get in!)
The toroidal transformer of my power amp hums and I have tried all the tricks in the world but I haven't succeeded to remove humming. Luckily the amp has a lifetime gurantee and the manufacturer promised to change the trafo for free.
My point is that you might not be able to remove humming and I'm 99% sure that a power filter won't help at all.
Tip: Try putting a hair dryer to same outlet with the power amps and put it on half speed. If it is DC offset that is causing the humming this should make it worse.
