Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th November 2004, 06:24 AM   #1
Default Triac regulator
I'm currently working on plans for an EDM (electrical discharge machining).
Bascically is cuts metal by controlled electric discharges. The problem I have is that I need to be able to change the voltage at currents up to about 10 amps with the voltage between 50 and 200 volts.
For current limiting, I'm using a high side fet to switch in series with an inductor. A comparitor measuring the voltage drop over a load sensing resistor will control the duty cycle of the fet.
For voltage, I was thinking of using a triac to chop the AC either coming out of a transformer or directly attached to the mains. Linear regulation is impractical due to the high current and voltage. I've done simple triac switching with a microcontroller before using mains to much success in making drag lights.
What I was thinking is to use a triac to switch a portion of a mains wave to bring the voltage down to what I need. Since you can't easily switch a triac off till the AC wave goes through zero, the uC must wait a certain amount of time before turning on the triac.
By turning on the triac at the appropriate time, only a certain portion of a wave will be going through the transformer.
If conservatively fused, can I eliminate the transformer alltogether?
I'm don't really want to find a 1500w transformer.
Is this a practical way of doing it?
Any comments?
Old 18th November 2004, 09:11 PM   #2
TwoSpoons's Avatar
Normally you will be controlling either current or voltage but not both at the same time: for a set voltage the current is controlled by the load, for a set current the voltage is controlled by the load.
The buck converter is probably your best bet, but if you're trying to handle 1500W I'd look at using an IGBT - drives like a FET, switches like a BJT, handles big volts and big currents easily.
Old 19th November 2004, 06:15 AM   #3
This is the site I've been basing my ideas around
http://cscott.net/Projects/FabClass/final/edesign1.html
I looked into it further today and it seems it does have voltage regulation
I just didn't understand how it was being used.
Sorry about that
on with the project
Need a Triac zedrider Parts 1 28th September 2007 03:38 PM
SCR or TRIAC? Wombat2 Parts 3 6th June 2006 03:21 AM
How to measure a Triac with a multimeter? Charles Hansen Parts 3 1st September 2005 02:25 AM
Triac Question vinay Pass Labs 8 26th August 2003 08:31 PM
triac's used as crowbar?? hugobross Solid State 19 12th August 2002 04:02 PM
Page generated in 0.08910 seconds (72.19% PHP - 27.81% MySQL) with 10 queries
