| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Most people don't list mouser as a source for the blue alps pots, but doing a little searching (they are listed incorrectly and not in the catalog) I have found this:
RK27 Has anyone purchased these from mouser? They are listed for $10 USD - seems cheap. I think its a 100k - can't tell if its log or linear. Any thoughts? Thanks, Seth |
#2 |
I bought a couple of these. Taper is best described as follows:
From http://www.rane.com/par-p.html#MN_taper MN taper (aka balance pot) Special taper developed for home stereo "Balance" controls. Consists of two sections (one for each channel) operating opposite each other. Exactly one-half of each section is a zero resistance surface (i.e., solid-copper or equivalent), the next 50% of travel is linear taper. Therefore for one channel rotating the slider through the first 50% of travel does not change the level at all, while the other channel is reduce from full to zero, and vice versa, with the middle position (usually featuring a center-detent) always passing full signal to each channel. Not what I was expecting; Alps part numbers are confusing at best. Some future preamp project, maybe... |
#3 |
Actually, it would work as a 4-channel balance control, because it has two sections and only one section is needed for stereo.
#4 |
Scratch that, one section per channel is required. Sorry if I misinformed anyone.
| Alps Blue Velvet | Bengali | Parts | 0 | 12th March 2009 10:12 PM |
| WTB : Alps Blue Velvet 100KB*2 (Japan) | ANALOG GUY | Swap Meet | 4 | 5th August 2006 08:07 PM |
| FS/WTT: Opamps for Alps Blue Velvet | seiko_citizen | Swap Meet | 0 | 24th October 2004 06:08 AM |
| ALPs blue velvet question - new to DIY audio | bscandanavia | Parts | 9 | 19th June 2004 03:09 PM |
| Page generated in 0.07571 seconds (73.05% PHP - 26.95% MySQL) with 10 queries |
