| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I wanted to share with the community here the recurring realisation that there are some things where size matters...rectifiers.
I have been popping delicate, little girly men sized 35 and 50amp rectifiers in my car amp test rig, so I decided to step up to the big boys on the block... These are the smallest in the series, 2 diodes per block. 1200v, 166amp avg @ 100c, 260amps rms, 3500amps surge. http://www.irf.com/product-info/data...ta/irkd166.pdf The ruler behind is in inches... Enjoy Stuart |
#2 | |||
Try 7000 amps dc, 29 Kiloamps surge...and deeese is only da 50 and 67 mm diameter product, you should see the 100 mm diameter stuff.. Cheers, John.. PS...yah, Youzes right...that's an F-22...make my day.. |
#3 |
#4 |
Yah, but they use the 100 mm stuff..in parallel..
BTW, where does the car fit in? John |
#5 |
No, now come on, there's no way for me to attach the cables, how am I supposed to hook those up. I can adjust from solder terminals to screw terminals, but how do I use them discs? Presumably there is some heatsinking involved too, though I am not sure how...
Nope, I'm just gonna have to stick with my, apparently barely adequate, but easy to use, blocks... I have some 13v/35 amp transformers, collectively they can power any piece of car gear I'm likely to try and fix, hopefully these rectifiers are up to the task, their smaller siblings most certainly were not. Stuart PS Bet my rectifiers sound better than your rectifiers, mine ring when dropped...something to do with the 4mm steel base plate they are built on...
#6 | |
The disks are actually the silicon wafer brazed to a disk of molybdenum. They are put into a hockey puck hermetic assembly, and the heatsink assembly compresses the disk, mine to the tune of 9 thousand pounds...for cryogenic use, I had to go to 12,000 lbs, as the tce's redistribute the clamping pressure in a non uniform fashion.. OH, forgot the best part....I can use mine for skeet shooting.. He he, John |
#7 |
Hm, I need to grab some of those for my welder.
(It's AC only output, rated for 230A. I'll grab a few MOT's and spare welding cable for the inductor.) Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
| Bridge rectifier vs Full wave rectifier | hilbert_mostert | Tubes / Valves | 4 | 28th April 2009 08:26 PM |
| 6CJ3 rectifier or 6D22S rectifier | 56oval | Tubes / Valves | 10 | 19th April 2007 09:48 AM |
| 81 Rectifier | Diy martin | Tubes / Valves | 4 | 14th January 2006 01:54 PM |
| Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? | zxx123 | Tubes / Valves | 4 | 21st February 2005 04:02 AM |
| Integrated Rectifier Bridge VS Rectifier Diodes | Sci | Chip Amps | 11 | 16th July 2004 02:43 PM |
| Page generated in 0.09897 seconds (77.44% PHP - 22.56% MySQL) with 11 queries |
