| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Account Disabled
How Works upper volt in car Amplifier???
i need it in Circuit and image (the upper volt is up from 12V in the car AMPLIFIER to high volts (30V + ) thanks alll !!!!!!!!!!!!.... |
#2 |
It's a special powerssupply called "switchmode". The basic idea is that you generate an AC wave from the car's battery DC, increase it's voltage via a (usually small) transformer and then rectify it again with a diode bridge to get DC again, but at a higher voltage. Usually the AC wave is square and high frequency, so the efficiency of this kind of circuits it's rather high (90% is not uncommon), yet, they're NOT trivial to design or build.
Rod Elliot ( www.sound.westhost.com ) had a few very good articles and proyects on these kind of psu's. |
#3 |
Account Disabled
I need Circuit to...
#4 |
The pdf is from On-Semi (formerly Motorola) of a high current, high voltage "off-line" switcher. Off-line switchers, as the name implies, take the juice right out of the wall socket and convert it to DC. The reason that I mention this one is that a PCB layout is given. Furthermore, you can omit the rectifier on the input since you will be taking 12VDC from the battery, and of course you will have to change the transformer, etc.
http://www.onsemi.com/pub/Collateral/MC33362-D.PDF Before you get started building a switcher, you should read the tutorials on National Semi and Linear Technology. Furthermore, Nat Semi has some easy to use design software on their site. http://www.linear.com/pdf/an73f.pdf http://www.national.com/ds/LM/LM2587.pdf International Rectifier has a good tutorial on switching ps transformer design on their website: http://www.irf.com/technical-info/appnotes/an-1024.pdf Pay very close attention to specifications of all diodes, inductors, capacitors etc. Why isn't TI mentioned here? I find their website unuseable. I was once a fan of Unitrode parts, but they have made a salad of the information. They are the largest company in the biz, however. Pity. |
#5 | |
http://www.sound.westhost.com/project89.htm Keld
"What is done by what is called myself is, I feel, done by something greater than myself in me." James Clerk Maxwell. 1879 |
#6 |
Account Disabled
Before Starting to build a "not trivial" switchmode PSU,
you might be interested to know, that there are a bunch of Step up Regulators that come in form of ICs. They can be for one voltage or be Adjustable. Some examples: LM2577 PDF download LM2588 PDF download just paste those two lines, one at the time, into Google Search, http://www.google.com/ the first is for max 3A max 37 volt out the other can deliver 5A I am sure the other guys here can give some more ICs gromanswe switching up |
#7 |
Account Disabled
thanks alllllllllllllllll !!!!!!!!!!!!
| 6 Volt Sony Power Amplifier | WSJ | Car Audio | 1 | 12th June 2009 08:09 AM |
| 6 Volt Sony Power Amplifier | WSJ | Vendor's Bazaar | 0 | 8th June 2009 02:11 PM |
| ZV9 upper limits??? | sandyhooker | Pass Labs | 4 | 27th December 2008 03:24 AM |
| Switching 230 Volt Transformer to 120 Volt | OMNIFEX | Parts | 10 | 6th April 2008 04:34 PM |
| good ESL amplifier that works with extreme capacitive loads | thadman | Solid State | 2 | 31st January 2007 11:20 PM |
