Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th November 2004, 06:55 AM   #1
Default resistors (newbie question)
This is a pretty easy question for you guys im sure and i think i know the answer but i wanted to check.
what is the reason that resistors are hooked up in series? i mean why not just use ONE 2k resistor instead of TWO 1k resistors? my thoughts were that its done for to keep the heat down? but for some reason that doesnt quite sound right.
Old 15th November 2004, 07:03 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
1 Withstand higher voltage becasue wihen you come up to a certain resistance value power isn't the limit, but the voltage is. Small 0.25W carbon, 0.6 W metall film can take max 250-300 volts.
2 You want more power dissipation and for some reason you can't or won't get a bigger resistor.
(Good question, not easy to realize the first answer.)
/Per-Anders (my first name) or P-A as my friends call me
Old 15th November 2004, 09:26 AM   #3
Circlotron's Avatar
Sometimes it is more convenient to use several smaller resistors on a printed circuit board because they fit the available space better, or because the far end of a long resistor would end up in some bad spot. With two in series you can make a U-turn with the ends right next to each other.
Another thought for low level signals - would several parallel larger value resistors make less noise than one single lower value part?
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 15th November 2004, 06:50 PM   #4
Swedish Chef's Avatar
For thermal noise - no. I can see some logic in your question since the noise sources will be uncorrelated but you can do the simple calculations if you are not convinced.
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction
Old 15th November 2004, 09:57 PM   #5
johnnyx is offline johnnyx  United Kingdom
I used 16, 1%, 10ohm resistors connected in series and parallel combinations to make a 10ohm 1% reference resistor for loudspeaker measurements. Power resistors are rare at 1% tolerance, so I have the precision of a small metal film with the power handling of a wirewound.
Old 15th November 2004, 10:14 PM   #6
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
Also sometimes to create values that aren't easily available
Old 19th November 2004, 03:13 AM   #7
make a 2K using 10 ohm resistors and at the end u have learnt the art of soldering.
Enjoy
Gajanan Phadte
question about resistors. scampo77 Car Audio 3 14th September 2008 04:15 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
crossover question about resistors? scooby1 Multi-Way 2 6th September 2005 05:13 AM
Quick question about resistors Ryssen Parts 0 18th January 2004 04:55 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Page generated in 0.08376 seconds (80.92% PHP - 19.08% MySQL) with 10 queries
