Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th November 2004, 09:17 PM   #1
Question Interfacing to TDA1543A
Trying to get an interface between a PIC and a TDA1543A working. I assume that the 3 input pins for the "A" version are the same as the non-"A" version (data/bit clock/select). These 3 pins are hooked up to PIC outputs. The L/R outputs are connected to 1k resistors to ground, for the moment.
I measure 2.2v on the reference pin, and 1v on the outputs. Seems sane, at least.
I know that the TDA1543A takes a Sony input format. I'm trying a simple test to set the L or R word by setting a level on the data input and applying a number of clocks. Then I change the select line, the input value, and apply the same number of clocks. I would expect this to fill one channel with all 0's and the other with all 1's.
Regardless of what I try, however, the outputs remain constant at +1v. Is my assumption about the input pins incorrect? Any ideas? I can try things out easily enough; just out of ideas for the moment.
Thanks,
--ian
24 bit ADC interfacing with ARM using I2S sukhdeep Digital Line Level 2 20th June 2009 03:37 PM
M50423fp & Tda1543a tbklbl Digital Source 4 28th October 2008 07:32 PM
Tda1543a S1 cm Digital Source 26 24th June 2005 06:46 AM
Fs: Tda1543a-s2 rbroer Swap Meet 6 21st June 2004 11:29 AM
Tda1543a DonJuan Digital Source 31 28th January 2004 06:39 PM
Page generated in 0.07001 seconds (72.34% PHP - 27.66% MySQL) with 10 queries
