| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
If I tie a 15 or 16 volt source to the output pin of an umpowered 7815 and 0 to its ground pin will this damage it. I want to be able to jump back an forth between two supplies -- one on board and the other outboard.
Any thoughts thanks |
#2 |
it might damage the IC...u can put a diode across from the input to the output to solve this problem though...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#3 |
Why do you need to keep the reg o/p connected when the external supply is in use?
Can't you just switch between them, rather than adding the ext. supply? |
#4 |
It seems to me that we did some checking once and the 7815 can sink current (it normally sources). It didn't seem to hurt it as long as the current was kept low. So it may work just fine.
They're cheap, so if you blow one up, oh well. Oh wait, you said unpowered...not sure about that. Try it! |
#5 |
u're not suppossed to stick anything after the regulator, and leave the regulator unpowered...check the app note.
www.national.com the diode thingy I mentioned is in the app note as well
| 7815/7915 dual supply hum problem | Lenn Art | Power Supplies | 8 | 22nd March 2011 09:57 PM |
| Pin compatible 7815/7915 replacements? | Isaac Sibson | Parts | 9 | 26th October 2010 04:05 PM |
| 7805 with adjR vs 7815 | wleediy | Power Supplies | 0 | 30th March 2008 11:18 PM |
| L7915/7815 vs LM2940CT15/LM2990T15 | Gasho | Parts | 0 | 13th April 2005 05:20 PM |
| 7815 not regulating. | JoeBob | Solid State | 16 | 8th September 2003 12:51 PM |
| Page generated in 0.06962 seconds (71.95% PHP - 28.05% MySQL) with 10 queries |
