Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
low noise transistor needed
Old 11th November 2004, 03:25 PM   #1
Ricren is offline Ricren
Ricren's Avatar
Default low noise transistor needed
Hi folks,
I'm looking for the lowest noise PNP small signal transistor for a microphone circuit wiith a 50 V power supply. I've been searching and a candidate would be the 2N5087, but I wonder if there's something better.
Could anybody suggest a better unit?
Thanks a lot.
Ric
Old 12th November 2004, 08:06 AM   #2
kilowattski is offline kilowattski  United States
kilowattski's Avatar
BC550C
Kilowattski
Old 12th November 2004, 10:31 AM   #3
quasi is offline quasi  Australia
quasi's Avatar
Default kilowattski !!!????
It's ok .... kilowattski meant a BC560C the PNP version of the BC550C.
If there is 50v across this transistor then the BC560 may not do.
Whew ...hope I got here in time.
Cheers
Old 12th November 2004, 11:01 AM   #4
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
BC550 , you are funny
Maybe SSM2220?
http://www.analog.com/UploadedFiles/...7SSM2220_b.pdf
Those are SO08 but I have DIL08 for sale
or MAT03
http://www.analog.com/UploadedFiles/...255MAT03_c.pdf
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 18 pcb's in interest.
Old 12th November 2004, 11:25 AM   #5
quasi's Avatar
What voltage sits across the transistor in question? Is it 50v or something else? If you don't know and have a cct we can work it out.
Cheers
Old 12th November 2004, 02:04 PM   #6
Ricren's Avatar
Default Circuit
Folks,
Thanks a lot for the suggestions.
I'm attaching the schematic of the "electret mic to balanced phantom power adapter " that I need to build.
Pins labeled XLR 2 and XLR 3 goes to the typical balanced input circuit of a regular mixing board. In that circuit you have 48 V DC applied thru a couple of 6.8K resistors.
So I think the voltage across the transistor (Vce) is way less than 48v. Anyway is nice to have voltage headroom, right?
Ric
Old 14th November 2004, 07:19 AM   #7
Quasi,
Unfortunately for me the 5 and 6 on the keyboard are next to each other. Thank you for catching that, but it looks like Per-Anders has won the prize for finding the lowest noise transistor I have ever seen.
Kilowattski
Old 14th November 2004, 08:52 AM   #8
mandat is offline mandat  Poland
There is another solution - THAT300 4xNPN, THAT320 4xPNP and THAT340 2xNPN. The main problem may be a low amplification coefficient.
http://www.profusionplc.com
Old 14th November 2004, 10:10 AM   #9
Can you change your mind? What do you think about specialised opamp like INA103 or INA163?
Look at Tomasz Brodniewicz's homepage
http://www.proaudio.nwz.pl/konstr_ina103.htm
You can find gif with manufacturer's application
http://www.proaudio.nwz.pl/pre_ina103.gif
author's application
http://www.proaudio.nwz.pl/ina103nowe.gif
PCB
http://www.proaudio.nwz.pl/inaboard.gif
and the last two in EAGLE format.
Application and PCB were done for dynamic micro.
Another link
http://www.mindspring.com/~benbradley/pre.html
Old 14th November 2004, 11:52 PM   #10
Ricren's Avatar
Default the circuit is great, belive me.
Mandat: Thanks for the sugestion. I actually use those ICs and they sound very nice.
But in this case, this circuit posted fits really well for the job. Is a version of a very clever circuit that Schoeps uses in their multi thousend dollars mics. Is minimalistic and does the job. In combination with a preamplifier with clean phantom power, it rocks.
The key is to use low noise transistors. I built it with BC558 and is a non go.
I'll chech the dual one that peranders suggested.
Tks again.
Ric
low noise transistor neededHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 10:42 AM
seeking: 1.5A+ low noise, high hFE transistor riotubes Parts 11 22nd October 2008 01:11 PM
Transistor sub help needed Geek Parts 25 8th December 2007 05:14 PM
Transistor specialist needed portlandlay Pass Labs 18 28th November 2005 11:51 PM
