| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am going to first start off and say I have very limited knowledge with electronics. I simply want to power a led, which will later be applied to a subwoofer project.
My first question is, if I want to simply test a bunch of leds just to see the color output, what's the easiest way to do this? (keeping in mind I need 1st grade education on this). Secondly, I would like to add an led to the front my subwoofer project for when the subwoofer receives a signal from the receiver, and is essentially on/running. This seems like a simple task, but from searching the boards this seems more difficult than I aniticpated. Any instructions? Lastly, I remember seeing some very small rectangular/square leds, perhaps 1mm x 2mm. Anyone know a source for these? Thanks in advance. |
#2 |
Well, it's hard to avoid Ohm's Law when figuring out the resistor to use with an LED. R=V/I where V is the voltage to drop across the resistor, and I is the current.
10 mA is a good rule of thumb to run most LEDs at, although they'll generally survice double that. 10mA = 0.010 amps The voltage across the LED depends on what colour it is. Red LEDs run at around 1.6V; other colours need more. Unless you're trying to run from a very low voltage supply like 3.3 volts this won't affect things much. So, if you have a 12 volt power supply, subtract 2 volts to allow for the LED operating voltage, and you have 10 volts to drop in the resistor. R=V/I= 10V/0.01 amps= 1000 ohms. At higher voltages you'll need to worry about the power dissipated in the resistor. With a 25 volt drop at 10 mA, the resistor would dissipate 1/4 of a watt, so you'd want to use a 1/2 watt resistor. (Power=Volts x Amps) Flat side of the LED is the negative lead. To easily test LEDs, get a 9V battery and put a 1k resistor in series to limit the current. The Wikipedia should have good explanations of concepts like Ohm's Law and Series connections. Series, parallel, and Ohm's Law will take you a long way in understanding electrical circuits. |
| Trade my blue LEDs for White LEDs | CaliforniaBob | Swap Meet | 7 | 26th March 2004 07:28 AM |
| WTT: Blue LEDs for Red & Red/Green LEDs | CaliforniaBob | Swap Meet | 2 | 9th June 2003 02:58 PM |
| LEDs | Tomo | Solid State | 4 | 29th September 2002 09:34 PM |
| Page generated in 0.06448 seconds (73.33% PHP - 26.67% MySQL) with 10 queries |
