Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th November 2004, 07:39 AM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default DIY plated through hole PCBs?
I wanted to know if there is a method to make double side boards, with plated through holes.
Does someone know such a method?
thanks
Alex
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 8th November 2004, 08:20 AM   #2
Electrons are yellow and more is better!
peranders's Avatar
One method is to tape on one side and create a groundplane. This pcb is made of a handmade original of black pcb tape. The picture shows a headphone amp made of Supertex mosfets. I was made in 1984-1986, not sure.
A second pcb is here
/Per-Anders (my first name) or P-A as my friends call me
Old 8th November 2004, 08:43 AM   #3
Bricolo's Avatar
Sure! But look at your red wima cap, and imagine you have to solder one of its leg to ground.
How do you do this?
Old 8th November 2004, 08:49 AM   #4
peranders's Avatar
In that case you have to lift it 2 mm or so. You can also drill an extra hole beside the cap and then bend the wire on the solder side.
Those big darkblue caps are solderd into the groundplane from the upper side. You must have a little technique, that's all.
If you check the second picture you can see the tin under the cap.
http://home5.swipnet.se/~w-50674/hif.../qsxm2_old.jpg
Old 8th November 2004, 09:18 AM   #5
Bricolo's Avatar
That's how I also did it.
But I wanted to know it the plated through hols technique was available to the average diyer
thanks
Old 8th November 2004, 05:04 PM   #6
Send a message via ICQ to SupraGuy Send a message via Yahoo to SupraGuy
I've seen a kit for through-hole plating, so it can be done. The through-hole is kind of like a rivet, and you flatten out the pads on either end.
There are 10 types of people in the world. Those who understand binary, and those who don't.
Old 8th November 2004, 05:34 PM   #7
kilowattski's Avatar
What you are looking for is called a "Via". It is not a plated thru hole but as the last poster put it a rivet type device that can be inserted so the top and bottom lands can contact each other.
Kilowattski
Old 26th November 2004, 12:42 AM   #8
There is a good web page that has some information on the bottom about DIY plated through holes. Not much info and it points to a process that you might not be using already but its worth a read:
web.media.mit.edu/~ladyada/resources/inhouseetch.html
I was wondering the same thing, but can only figure on soldering from the top when required. If you find more info, please pass it along.
David
Old 26th November 2004, 05:03 AM   #9
Bricolo's Avatar
here's what I found
http://www.cif.fr/new/produits_aff.p...5&p=346&lng=en
I haven't bought it now
Old 26th November 2004, 05:46 AM   #10
Henrik Juhl's Avatar
Reichelt (www.reichelt.de) has what you are looking for - do a search for 'BEL FAVORIT' and you will find a handpress which presses a bushing through the predrilled hole and sets it.
I do not have any hands-on experience in this, but it looks straightforward and doable - the price is 187 € though.
If you try it - please let us know your observations
Henrik Juhl
Making plated through-hole PCB rozon Parts 2 1st May 2009 01:57 AM
FS: Aleph-X PCBs , NIGC PCBs , OPA541AM OpAmps e.lectronick Swap Meet 22 4th March 2009 07:38 AM
Direct Gold plated PCB reMC Digital Source 0 9th April 2008 03:32 PM
Gold Plated BNC Hardware fmak Digital Source 129 26th March 2005 05:25 PM
Gold plated jacks to... johnferrier Everything Else 1 21st December 2003 05:09 AM
Page generated in 0.10656 seconds (76.28% PHP - 23.72% MySQL) with 10 queries
