| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have a Technics SE-A3MK2 Amplifier which is 120V we have 240V here, the amp has 2 identical transformers in it (no longer available) the only thing i can think of is connecting primary windings in series & connecting all secondary windings in parallel
would this be the way to go? is there any issues to look for? Regards Baily
.:Ride the Lightning...Feel the Thunder:. - Technics Triple Thunder www.welcome.to/Technics |
#2 | |
I could get what I need by running new pairs from the main distribution panel to the point of service (one 120v circuit, one neutral and a ground). Phil |
#3 |
Sorry, didn't answer your question. You could split the 240v circuit to two 120v circuits then apply one 120v leg to one 120v primary coil and the other 120v leg to the other primary coil. But than we are back to my first post... No, No, No.... Can not have current travel on earth safety groung wire.
Re-read my post above for best practice and as always safety first. Phil |
#4 |
to clear this up... this amp was from usa
in Australia we have 240V AC 50hz (single phase) 3 phase is 440V here the amp has no gnd/earth pin double insulation
#5 |
ok..... i done it orready... it does have a twist,
the primary windings of the x'fmrs were in parallel, with one x'fmr primary connected in opposite polarity - reason being to create a C.T. winding from 2 identical x'fmrs in mirror image (180deg phasing) which was utilised in the front end circuitry... to keep v/drop even over each x'fmr i parallel conected the power amp (main secondary windings) in parallel but in mirror image the amp works a treat- i tested for voltage drops across secondaries (phase shift etc) all come up virtually 0V on a 3VAC range so i thank myself on this outcome i hope it is of some use to fellow aussies who cop a narrow voltage ranged US amplifier - the same model that goes to the rest of the world ALL are Multi Tap primaries (maybe the manufacturer does not trust americans to get the voltage selector right) though i wonder why as they run on the lowest voltage (i dont think the amp will be damaged from undersupply - it may not run, bit wont be damaged (afterall they recommend that a variac be used to check after repair) stay tuned - Baily
| Power transformer | Alain Dupont | Tubes / Valves | 4 | 4th April 2005 09:12 PM |
| Transformer ok for power amp?? | 6502dude | Solid State | 7 | 3rd April 2005 01:02 PM |
| power transformer help !!! | jim | Tubes / Valves | 2 | 9th January 2004 09:59 PM |
| toroid Transformer as power Transformer for tube | tone | Tubes / Valves | 7 | 11th February 2003 08:57 AM |
| Good price on huge power transformer for power amp. | G | Solid State | 3 | 15th September 2002 01:23 PM |
| Page generated in 0.08412 seconds (76.73% PHP - 23.27% MySQL) with 10 queries |
