Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th November 2004, 05:28 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Angry Printing PCBs directly from National Semisoncudtor's datasheet
Has anyone tryed to make a PCB with the reference boards given in some NS datasheets?
I did it this afternoon, printing the top and bottom layer from the pdf, beeing careful to switch off the automatic resize, in order to print at 100% scale
Then, aligning the 2 sides, UV, revealing...
Back home, happy that the process worked well... I took my components and looked if the pads were correctly placed.
And...
The board isn't at the right scale! It's too small
2 double layer boards for nothing...
What's my error? I printed the boards at 100% scale, I don't understand.
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 4th November 2004, 05:46 PM   #2
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I converted the actual gerber data to a pdf for you, if you print the pdf without scaling, it should work perfectly. There are also measurements on the layer to verify the dimensions.
I haven't used the files to make any boards. I simply downloaded the gerber files from NS, and used the free ViewMate 8.4 software to convert them (along with a print-to-pdf software package)
Brian
Old 4th November 2004, 05:52 PM   #3
Bricolo's Avatar
Hi Brian,
Thanks for helping, but it's for the LM4651 & LM4651, not for the LM4780
Here's the datasheet
http://www.national.com/ds.cgi/LM/LM4651.pdf
Try to print the page with the pcb, and look if the footprints are OK (the 4652 in the center of the PCB has the same package and footprint as a LM3875, so you can use this one to test)
Old 4th November 2004, 06:16 PM   #4
BrianGT's Avatar
Originally posted by Bricolo
Hi Brian,
Alright, I just assumed it was the LM4780. Here is the top layer of the Class D LM4651 board:
Brian
Old 4th November 2004, 06:18 PM   #5
BrianGT's Avatar
Here is the bottom layer (file was to big to combine).
If I print it without scaling, it prints perfectly.
Brian
Old 4th November 2004, 06:21 PM   #6
Bricolo's Avatar
thanks, I'll try that
How did you convert it?
Does it also print to small directly from the datasheet?
Old 4th November 2004, 06:42 PM   #7
Bricolo's Avatar
Thank you Brian, your files are at the right scale
any idea why the ones from the datasheer aren't?
Old 4th November 2004, 06:56 PM   #8
Mr Evil is offline Mr Evil  United Kingdom
Now you have learnt a valuable lesson: Physically lay out components on a printout before etching a PCB! That way you catch scaling errors like this, and in the case of newly designed layouts, you can catch any clearance problems that may not be obvious otherwise.
https://mrevil.asvachin.eu/
Old 4th November 2004, 07:24 PM   #9
Bricolo's Avatar
Yes, now I know
Old 4th November 2004, 09:39 PM   #10
jackinnj's Avatar
I believe that National put the Gerber files on their site -- it's a zipped file -- you can take the Gerber files and open them in a Gerber Viewer, then print from the Gerber Viewer -- you can print as a bit-mapped file. Pentalogix Viewmate is available as freeware.
btw, it's always a good idea to look over your PCB's with a Gerber viewer -- great at spotting things which your software forgets.
FS: Aleph-X PCBs , NIGC PCBs , OPA541AM OpAmps e.lectronick Swap Meet 22 4th March 2009 07:38 AM
National ICs for PCBs elementx Swap Meet 16 26th July 2007 06:55 AM
Direct to PCB printing.. cuibono Parts 0 24th July 2007 01:33 AM
Printing PCBs eeka chu Parts 11 15th April 2007 01:32 AM
Printing software AuroraB Everything Else 4 18th April 2006 02:22 PM
Page generated in 0.09918 seconds (79.15% PHP - 20.85% MySQL) with 11 queries
