Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
nightmare transistor problem!!
Old 4th November 2004, 01:23 AM   #1
fatboy is offline fatboy  Wales
Default nightmare transistor problem!!
Hi Guys,
Nice forum, Ive had a good read, and found some interesting discussions.
Anyway, Ive got a power amp, with 2 tranys gone short on the output stage. They are a 2SC3856, and a 2SA1492. I am having trouble finding a supplier here in the UK, so I was wondering if you could recommend an equiv.
Ive searched the forum, and come up with a 2SC3281 and a 2SA1302 which may do the job. Can someone just confirm that it will be a straight swap, as they are quite expensive here and I dont want to buy them if they are no good.
If Im wrong, can you recommend anything else I could use.
Thanks chaps,
Martyn....
Old 4th November 2004, 04:06 AM   #2
jcx is offline jcx  United States
don't know if they are good subs for your original pair but onsemi (fromerly motorla) MJL2381A/1381A have superior SOA specs - less likely to blow again
Old 4th November 2004, 07:46 AM   #3
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
You can't go wrong with the MJL1302/3281 , as they are similar but more rugged.
Cheers
Andrea
Old 4th November 2004, 08:00 AM   #4
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Exclamation Re: nightmare transistor problem!!
Originally posted by fatboy
Hi Guys,
Thanks chaps,
Martyn....
Hi Martyn, I second the suggestion for the Onsemi parts but you have also to replace the drivers, check all diodes, emitter resistors and the well being of the protection circuit.
Old 4th November 2004, 09:01 AM   #5
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Have you tried Profusion here in the UK? Try looking under Sanken.
Avoid the 2SC3281 and 2SA1302 as any you get will most likely be fake as they haven't been made by Sanyo for about 10 years and were replaced by 2SC5200 and 2SA1943 (which Profusion sell).
I would also replace the drivers for good measure as they are likely damaged and may fail later down the line.
Old 4th November 2004, 05:35 PM   #6
Thanks folks,
The only ones I can find here are the 2SC5200 and 2SA1943 suggested by Richie. I can only buy 10 at a time of each from Profusion, which would be a bit silly as I only need 1!
Im trying a few suppliers, who are getting in touch with a price
Thanks again for your help though.
Old 4th November 2004, 06:16 PM   #7
audiopro is offline audiopro  Canada
Try Farnell. They stock the OnSemi MJL's noted by previous posters.
The 2SA1301/2SC3281 are available from Digi-Key in the US. They're cheaper but the shipping will probably be too expensive.
These are not fakes, by the way. Toshiba, not Sanyo, makes them.
Old 4th November 2004, 06:44 PM   #8
Did it Himself
Yes, Toshiba not Sanyo. My haste
I think RS do the C5200 and A1943.
I cannot stress enough, take heed of Elso's and my advice to replace the drivers as well, unless you want to be doing the job twice.
nightmare transistor problem!!Hide this!Advertise here!
krell ksa 300s right channel dead maybe transistor problem?? yipyip55 Solid State 25 19th July 2012 08:21 PM
Soundstream Rubicon 702 Output transistor Problem? tyu527 Car Audio 10 29th August 2008 07:37 AM
SI nightmare gvr4ever Class D 16 20th September 2006 05:20 AM
New Nightmare (Guitar Amp) Trout Instruments and Amps 48 27th November 2005 03:33 PM
Nightmare soldering problem with some resuscitated cones VvvvvV Multi-Way 1 5th August 2004 08:24 PM
Copyright ©1999-2017 diyAudio
