| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello
The above device is used in the buffer and line stages of a Sony TA-E88 pre-amplifier, one of them has gone , i have searched all over for one and cannot find any.I tried replacing the fet with 4 2SK30a fets which worked but not very well, i could not get "0" volts between the two sources of the fets. So I am wondering if anyone knows where i can find one these or has some that would be willing to sell to me or knwos of a way around the problem, i have uploaded a jpeg of the circuit showing the original fet in circuit. Thanks Gary http://www.btinternet.com/~swlthr/ebay/IT500.jpg |
#2 |
Hi Gary,
I own one of these per-amps, unfortunately I have no spares. But did you try to adjust the balance with Rt301? I would expect that that is necessary even when replacing them with the original IT500's. Another option would be to buy a bunch of fets that come close and select a matched quad. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
Hello Jan
Thanks for your reply. Yes i have tried setting the offset voltage with the pre-set but i cannot get less than 300 mv dc on the output, if try the working It500 from the other channel it works. Gary |
#4 |
You could try two pairs of two matched fets, or two pairs of two in a single package.
Wait, did you try to swap the individual fets of the four you have used? There must be a combination that lets you get to zero, I would think. Jan Didden
#5 |
This is a problem, i do not know how or where to buy matched fets, i know sony used to make matched pairs in a 6 pin package (2SK97) but i cannot find these either.
Fets are not my thing when it comes to understanding them. Gary |
#6 |
The were made by ge/intersil, I have a data sheet somewhere.
Either HP or Tektronics used them, but using an in house numbering system, If I can find it I will post the cross reference. Regards James |
#7 |
Hello James
Thanks for that, could be worth a try. Gary |
#8 |
No, they were definitely packaged in a SONY marked package. I have a source that still had similar chips for a TA-N88. I bought all their stock of it, 6 pieces.
I will call them next week for this, small chance buth worth a try. Jan Didden
#9 |
Hello jan
Thanks for that, the ones i have in my pre-amp are just marked "IT500" followed by a date. Just out of interest, some of the tantalum capacitors failed in this pre-amp, which what i think caused the fet to blow, so i changed every single tantalum cap for a stargetz audio grade electrolytic capacitors, not only did this solve some of the problem but it improved the sound aswell, making the sound a little richer and the soundstage wider. Gary |
#10 |
<<<<No, they were definitely packaged in a SONY marked package. I have a source that still had similar chips for a TA-N88. I bought all their stock of it, 6 pieces.
I will call them next week for this, small chance buth worth a try. Jan Didden __________________ / The brain is logical - the mind may not be>>> Tell me Jan what sort are the ones you have for the TA-N88? Gary |
| Sony CD - Laser replacement/Availability | Henrik Juhl | Digital Source | 23 | 4th February 2012 04:48 PM |
| VFETs replacement, Sony TA-5650 | pietres | Solid State | 2 | 7th October 2008 02:07 PM |
| Consumer level replacement for Sony X555 ES | FrankWW | Digital Source | 0 | 12th May 2008 06:40 AM |
| Sony TX-183S replacement/datasheet ? | Optical | Solid State | 2 | 7th May 2003 10:18 PM |
| Page generated in 0.09586 seconds (82.16% PHP - 17.84% MySQL) with 10 queries |
