Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th July 2002, 01:31 PM   #1
Account Disabled
Question I need information about STK4050V
hi all!
I need information and circuit of STK4050V
Thanks!!!...
Old 4th July 2002, 02:20 PM   #2
e96mlo is offline e96mlo  Sweden
This site
http://www.datadart.com/al/sanyo/sanyodata.htm
contains the data sheet. It's also a good idea to check the data sheet for STK4048XI as it is contains a bit more information and as they are quite similar.
/Marcus
Old 4th July 2002, 02:35 PM   #3
Account Disabled
thanks!
but in the site not have a circuit of STK4050V
Old 4th July 2002, 02:37 PM   #4
Did you even bother to look in the data sheet?
/Marcus
Old 4th July 2002, 02:38 PM   #5
Freddie is offline Freddie  Sweden
STK4050 is there.. You didn't look very carefully did you?
http://www.datadart.com/al/sanyo/STK4050V.pdf
Old 4th July 2002, 03:00 PM   #6
Account Disabled
THANKS!!!
and HOW MACH AMPER THE STK4050V IS NEED?
i now is need 66V but i dont now how mach amper (A) is need??
Old 4th July 2002, 03:13 PM   #7
Ohms law:
U = R*I => I = 66 V/8 Ohm = 8,25 A
16,5 A is needed for a 4 Ohm load. But these are peak currents so 8,25 A/(sqrt(2)) = 5,8 A continous and the double for 4 Ohms.
And add some to count for the losses...
/Marcus
Old 4th July 2002, 03:35 PM   #8
Account Disabled
THANKS U!!!
I build a amp With 2 STK4050V IN 8 Ohm
soo i need a power 66V ~ 16.5A in a 8 Ohm (for two STK)
or 66V ~ 30A in a 4 Ohm ( for two STK)...
yes??
Old 4th July 2002, 03:47 PM   #9
Account Disabled
if .............
66V ~ 8Ohm (IN STK4050V) = 200W R.M.S
soo....
66V ~ 4Ohm (in stk4050V) = W ????
Old 4th July 2002, 03:53 PM   #10
U=R*I
P=U*I
With these formulas you can do most of the calculations you need. But remember that Up-p = (sqrt(2))*Urms and the same for current.
This means that the power doubles when you take half the load.
The transformer you need will be quite large (>1000 VA).
/Marcus
STK4050V, for real! Usher Chip Amps 17 22nd March 2008 03:45 PM
Stk4050v steffmeister Chip Amps 1 22nd September 2004 02:56 PM
Stk4050v to M2 implant Junfer Chip Amps 6 8th April 2004 12:46 PM
STK4050V PCB's halvardf Solid State 3 1st September 2002 03:24 PM
Page generated in 0.09802 seconds (78.97% PHP - 21.03% MySQL) with 11 queries
