| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I need to split a balanced connection without impacting the balancing (if possible). The problem is: one side of the split will go to an unbalanced input. I would think that a simple splitter would unbalance the line and I would lose a lot of common mode rejection. I'm trying to keep the signal path minimal - so I don't want to start messing around with op amps or transformers if possible.
Basically, I'm setting up a biamped system such that the natural rolloff of the high packs is the high pass "crossover". My active low pass filter for the sub has only unbalanced inputs. Thanks i advance for help. |
#2 |
I tried the simple option (no transformer) and the sound was fine - so, no need for big insight any more, I suppose.
| Tapping master clock | habsrock93 | Digital Line Level | 10 | 8th November 2008 01:41 AM |
| Firewire or USB device for tapping I2s | lucpes | Digital Source | 1 | 8th November 2006 05:44 PM |
| Distributed Load/Balanced Bridge Connection | NickC | Tubes / Valves | 1 | 1st October 2005 09:38 PM |
| I2S tapping to M-audio Delta 44 | Kohjin Yamada | Digital Source | 0 | 9th July 2004 06:58 AM |
| Page generated in 0.07573 seconds (75.04% PHP - 24.96% MySQL) with 10 queries |
