| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Ok, Im swapping out the opamps in my dvd player to AD8620's. Im adding 47uF Elna decoupling caps from pin 8+ to ground, and pin 4- to ground. I was told to just "stack" them over the existing .01uF ceramic SMD caps. My question is the pole orientation of the elna's. Now the pin 8 is easy + to +, - to gnd. How do I orientate the cap from neg to gnd on pin 4? pos on cap to pin 4, neg to gnd, or vise versa? Thanks in advance!
#2 |
It may be a stupid question, but can someone take a sec to answer me? Going from DC -11v on opamp to gnd through a electrolytic cap. Where does the pos+ on the cap go? To gnd or -11v?
#3 |
The (-) marks on the capacitor always goes to the smallest voltage potential on the circuit. So, for the positive supply, your cap should have its negative marks on the ground when other cap terminal goes to (+V). Fot the negative supply, the other cap should have its negative mark to (v-) and the other positive terminal on the ground.
Luke123 |
#4 |
Yes, - doesn't always go to ground
I learned it the hard way
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
#5 |
Thank You very much!!!!
#6 | |
#7 | |
mine thought it was a rocket, and flew through the room
| Bipolar Caps for decoupling? | jtsaudio | Parts | 7 | 29th March 2009 11:35 AM |
| Decoupling caps for PCM58J | beauty_divine | Digital Source | 1 | 4th October 2007 04:37 PM |
| Decoupling caps(again) | argonrepublic | Parts | 2 | 10th May 2005 10:32 PM |
| decoupling caps | argonrepublic | Parts | 4 | 8th May 2005 10:20 PM |
| Best Decoupling caps for TDA1541 | mrstone | Digital Source | 0 | 27th January 2004 02:56 AM |
| Page generated in 0.07591 seconds (77.74% PHP - 22.26% MySQL) with 10 queries |
