Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd October 2004, 11:34 AM   #1
falcott's Avatar
Question Negative volts and grounding in bench power supply
I'm adding a variable current regulator to my bench supply (0-30v dc) following a schematic in National's LM350 data sheet. I need approx -5v to -10v for the regulator. I know that I can use a 7909 regulator for this, which has 3 pins: input, output and ground. Where does the ground pin go to? Assuming that I take negative from the bridge to the input pin, do I ground the regulator via an electro cap to the positive rail?
Any help appreciated!
"Everything should be made as simple as possible, but not simpler." - Einstein
Old 23rd October 2004, 01:08 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
It is not clear exactly what yuo want to do. Assuming you have a bridge to get the 0-30VDC for the main supply, you want to make neg voltage from the same bridge? I don't think you can do that.
Or do you want to make a neg voltage with respect to the +30V point?
Jan Didden
Old 23rd October 2004, 07:14 PM   #3
falcott's Avatar
To clarify, look at National Semi's LM350 data sheet (for example here ), "Adjustable Current Regulator" on p.10.
Thanks for your response, Jan.
Old 23rd October 2004, 07:30 PM   #4
jackinnj's Avatar
you can derive a "negative" voltage from a single positive supply by using an inverting switching regulator -- National Semiconductor has several examples on their site. Just use a linear regulator following the switcher to clean up some (not all) of the switch transients.
Old 23rd October 2004, 09:20 PM   #5
falcott's Avatar
Something like the LM2576?
If I use the 7909 on the output to clean up the transients, that still leaves me with the question as to where the ground pin is connected.
Or, using an adjustable LM2576 set at the desired voltage, can I simply put, say, 2 large caps on the output, instead of the 7909?
Thanks for the leg-up!
Old 23rd October 2004, 11:59 PM   #6
sek is offline sek  Germany
When you have the switcher 'create' a negative output voltage, it's reference would be the old supply's ground, because this is where you want it to be negative from.
Then, this also becomes your ground for the 7909, because it's still where you want it to be negative from.
This should then be a +30V <-> 0V <-> -9V supply at this stage, right?
Also, you want caps and the 7909 at the switcher's output, because it really creates noise and spikes.
Old 24th October 2004, 12:22 AM   #7
moamps is offline moamps  Croatia
the simplest (and maybe the cheapest) way to get negative source is by using an additional small transformer 9V/2-3VA, small bridge and electrolytic capacitor without any stabilisation (load is CS).
Milan
Old 24th October 2004, 12:30 AM   #8
jackinnj's Avatar
Milan
nah, a 3524 or even a 555 is cheaper than a transformer and takes up a fraction of the space. you just have to invest a fraction of intellectual capital to design the thing.
Old 24th October 2004, 09:44 AM   #9
falcott's Avatar
Originally posted by sek
When you have the switcher 'create' a negative output voltage, it's reference would be the old supply's ground, because this is where you want it to be negative from....
Thanks for the explanation, sek. Just the sort of logic I was looking for
Thanks Milan. I agree, and yet it sounds a bit too easy. I do like a little challenge occasionally (well, it is a big one for me at present ). I will resort to that scheme if I have to, but I would like to work out a way of doing this with the original transformer and bridge if I can
See above. Thanks for your vote of confidence, jackinnj . I'm still not sure that I know what I am doing, however...
I'm looking at the possibility of using the MC34063 chip (ON Semi data sheet ). Will it be a quieter/smoother option, compared to the LM2576? Maybe the 7909 won't be so vital??
Thanks all!
Old 25th October 2004, 09:37 PM   #10
janneman's Avatar
Originally posted by falcott
[snip]Thanks Milan. I agree, and yet it sounds a bit too easy. I do like a little challenge occasionally (well, it is a big one for me at present ). I will resort to that scheme if I have to, but I would like to work out a way of doing this with the original transformer and bridge if I can [snip]Thanks all!
Falcott,
Please don't think too fast it is 'too easy'. Remember the question you started this thread with? That would be considered 'too easy' a problem by many. Don't want to discourage you, just trying to increase your chances of succes.
Jan Didden
Programmable Bench Power Supply? samsagaz Parts 1 22nd January 2008 03:21 AM
Replacing meters in bench power supply artb Parts 2 20th August 2006 12:19 PM
My new bench power supply Circlotron Equipment & Tools 7 28th April 2003 04:29 PM
bench power supply jethari Parts 1 14th March 2003 06:31 PM
My bench power supply.. deepanger Solid State 71 18th February 2003 08:56 PM
Page generated in 0.13362 seconds (81.21% PHP - 18.79% MySQL) with 10 queries
