Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd October 2004, 07:22 PM   #1
nick78 is offline nick78  United States
Default needed: 2SA1302
I need a single Toshiba 2SA1302 to repair an amp that I have...
I have read about the problems with counterfit/fake components and was wondering if there is a known reliable/safe source for these parts? I don't mind paying a premium in price to be sure it's the right part.., and I'm thinking I might buy two or three, in order to cut one open to verify it's the right stuff.
I know there are "better" replacements, but I don't want to replace the entire output section or modify the overall design. I just want to replace the blown part.
as an aside; what would cause a 2SA1302 to short across all pins? The device measures as a dead short from any pin to any pin. The amp worked the last time it was used and was fine when turned off. The next time it turned on it simply blew the fuse immediately.
any info is helpful.
thanks!!
Old 23rd October 2004, 02:23 PM   #2
Toshiba haven't been making these since 1999, so ALL of the ones you can buy now are fakes (been caught badly by this recently).
However ONsemi make MJL1302, as replacement. Reliable ONsemi distributors such as Farnell will have good ones.
Do you know history of amp? - could possibly already have fake transistors. Try splitting the dud one to have a look.
Cheers
Old 23rd October 2004, 06:10 PM   #3
i know the amp has had two previous owners - both deny that it's ever been repaired, and based on the way it came apart, I don't think it's ever been opened up before.
i've tried splitting open the dead '1302 but so far it hasn't split. I whacked it good with the handle of a screwdriver on the side of the transistor about 50 times but only succeeded in creating a slight chip around the "ear".
attached is a pic of it with the slight damage from my attempts to break it open
I went ahead and ordered a couple 2sa1302's from digikey (and a couple of 2sa1943 as well); when i searched the forum a few people mentioned that digikey buys straight from toshiba and they should not have fakes (thus they should have NOS)...well, i ordered a couple and when I get them, will attempt to split one open and see. will post pics. if the 1302's are good I'll use them, if not then i'll use the 1943's, and if THOSE are fake..i guess i'll go with onsemi MJL1302. I wanted to keep the transistor as close as possible to original to avoid any unintended affects on the amp..
Old 23rd October 2004, 08:53 PM   #4
sam9 is offline sam9  United States
sam9's Avatar
In the US, www.digikey.com and www.arrow.com still stock these. They are big distributors who get their stock either from Toshiba, still have stock on hand from Toshiba or have other reliable sources. At least I was told that when I asked.
This is repeating what you already know.
Your other option is to replace ALL the NPN/PNP pairs with 2SA1043 and 2SC5200. These are almost identicle to the originals - I think it unlikely that substituting these would change the sound of the amp in any discernable way.
Old 24th October 2004, 03:18 PM   #5
A sharp wood chisel will split them easily.
Cheers
Old 24th October 2004, 06:21 PM   #6
Looks like a real one. ruler is mm, the 'chip' is about 5mm per side.
Old 25th October 2004, 12:52 PM   #7
Yep, that looks like original. All the fakes seem to have the chip covered in a white silicon stuff.
Cheers
Old 28th October 2004, 06:33 PM   #8
K-amps is offline K-amps  United States
K-amps's Avatar
Cheers
Did'nt original 1302's come is green packaging?
Old 28th October 2004, 07:47 PM   #9
crippledchicken's Avatar
if you haven't yet, i'd be sure to check all drivers as well
Old 2nd November 2004, 02:16 AM   #10
well, i'm not much of an electronics genious (though i imitate a good one). i could desolder all the drivers but...man, it's a pain.
The amp design uses a pair of NPN/PNP each paralleled. When I removed the shorted 1302, I ran the amp on the one remaining 1302 (test purposes only) and it sounded fine...so i'm assuming everything else is good...(fingers crossed). it's a subwoofer amp.
I got three new 2sa1302's from digikey, and sacraficed one for "testing" purposes. am happy to report it's a real one. see attached image.
Fake 2SA1302 transistor steevo Solid State 18 15th November 2011 04:32 PM
Replacement 2sa1302 Fredmullegun Solid State 3 7th August 2008 02:15 PM
2SA1302 and 2SC3281 Diode Solid State 32 15th October 2003 04:05 AM
Possible Counterfeit 2SA1302's Jonathan M Solid State 13 6th January 2003 12:27 AM
Page generated in 0.10961 seconds (80.20% PHP - 19.80% MySQL) with 11 queries
