Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th October 2004, 03:51 PM   #1
BlackCatSound's Avatar
Default Replacement for WM60/61 microphones
I've been looking for some Panasonic WM60/61 mic capsules but it looks like they are no-longer in production.
Does anyone know of a suitable alternative to these mics?
Ta!
Old 20th October 2004, 10:42 PM   #2
moamps is offline moamps  Croatia
Default Re: Replacement for WM60/61 microphones
Monacor MCE-2000
Milan
Old 20th October 2004, 10:50 PM   #3
I thought the MCE2000 was a panasonic capsule renamed by Monacor?
I can't find them either.
Old 21st October 2004, 03:46 AM   #4
BrianL is offline BrianL  United States
Digikey lists the various WM-60/61 capsules on their
web site.
bel
Old 21st October 2004, 06:50 AM   #5
http://www.monacor.com/int/en/produk...pr=EN&typ=full
Web in UK: www.monacor.co.uk
Old 21st October 2004, 06:59 PM   #6
web site.
They are all listed non-stock, I gave them a call and they said they were obsolete.
Old 21st October 2004, 07:47 PM   #7
All the Panasonic capsules are about 6 or 7 mm across, so I suspect there probably won't be much difference in the response due to diaphragm/wavefront related issues. I'd even guess they're all pretty well flat up to 8 kHz or so simply because the things won't change the frequency response until their size is a significant fraction of the wavelength, modulo back chamber resonances which I also suspect is well above the region of interest.
Francois.
Old 21st October 2004, 10:15 PM   #8
dayvel is offline dayvel  United States
Digi-Key shows 24844 WM-61As in stock.
Old 21st October 2004, 10:24 PM   #9
You are right, their search doesn't work very well
If you search for 'wm6' you get the 60, 62, 64, 65, 66 and 67. If you search for 'wm-6' you get the whole lot. Daft!
I think I've found a source of the MCE2000.
Old 22nd October 2004, 12:59 PM   #10
Henrik Juhl's Avatar
Default MCE2000 = WM-60/61 ??
Can anyone actually verify that the Monacor MCE200 and the Panasonics are indeed the same breed? Anyone done any measurements/caibrations that care to comment?
Henrik Juhl
xfmrs for microphones hitsware Everything Else 1 8th May 2008 09:46 AM
Difference between microphones Mike150 Tubes / Valves 1 19th May 2006 12:33 AM
Wanted: a couple of Pansonic WM60 or (61) Jolt Swap Meet 3 29th July 2005 10:01 AM
SPL microphones? thylantyr Multi-Way 3 18th June 2005 06:19 PM
Cheap microphones? pentium Everything Else 0 30th October 2003 02:50 PM
Page generated in 0.08735 seconds (82.06% PHP - 17.94% MySQL) with 10 queries
