| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
This fuse is blown in my Sony audio system.
The printing on the PCB is... F905, ICP905 1.25A125V SSFR SOC On the fuse it is written... SOC 1250 It is a leaded fuse with a square body with axial leads. Can anyDIY tell me what is this type of fuse. Thanx in advance Gajanan Phadte |
#2 |
It looks like SOC is just the make:
http://www.fuses.cc/info/japaneseFuseDaito.asp http://www.san-o.com/ SSFR appears to be the type of fuse: http://www.san-o.com/Fusetype/Stdfuse/picodat2.htm "high reliability with low arcing" The fuse rating is 1.25 amps at 125V If it's impossible to obtain an exact replacement, possibly a small ceramic fast-blow 1.25A fuse could be substituted (wrap some solid wire around the ends of the fuse and solder). That's at your own risk of course; officially I do not recommend it. |
#3 |
Thanks dangus
SOC stands for SOC corporation this is the fact of SSFR The SSFR is UL Recognized to UL 198G. The ULSSTR is UL Listed to UL 248-1, -14. These are High Reliability devices with very low arcing when compared with conventional fuses. This will be important for precision current limiting applications. I had opened the fuse. It has a pasted cover. I will join the remaining ends of the fuse wire and hope for the best. |
| Fuse housing melting but fuse not blowing, ppi amp | rawadia | Car Audio | 21 | 2nd August 2008 10:39 AM |
| Re : BL type & GR type of transistor for Aleph-Ono | Arion | Pass Labs | 4 | 29th January 2007 06:15 PM |
| Why main fuse and not rail fuse? | digital desire | Solid State | 10 | 3rd December 2006 08:07 PM |
| amp rating for fuse and fuse holder? | riotubes | Parts | 5 | 27th August 2006 03:10 AM |
| blade type fuse holders | maylar | Parts | 0 | 23rd March 2004 04:00 PM |
| Page generated in 0.07578 seconds (73.50% PHP - 26.50% MySQL) with 10 queries |
