Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th October 2004, 03:01 PM   #1
sam9 is offline sam9  United States
sam9's Avatar
Default Potentiometer components
Anyone know a source where you can buy the comonents of pots that one can then assemble in to as many "gangs" as desired?
The Allen-Bradley "mod pots" look like they would be suitable, but I can not find anywhere that sell just the pieces -- only assembled units.
Old 18th October 2004, 03:35 PM   #2
cpemma is offline cpemma  United Kingdom
Vishay also do a few ranges of modular pots, datasheets here.
Old 18th October 2004, 07:45 PM   #3
Bill Fitzpatrick's Avatar
Default Re: Potentiometer components
I tried to find the same several years ago and had no luck either. It may be possible to buy some surplus pots, get some threaded rod and assemble into what you need. I didn't follow through with that idea but it looked practical.
Old 18th October 2004, 08:07 PM   #4
Default What About Going Digital
Have you considered going digital. A DS1802 digital pot from Maxim is VERY easy to implement. I run mine from a +/-2.7V split supply. These operate from pushbutton controls, you could easily "share" a button for several channels.
Old 18th October 2004, 09:57 PM   #5
sam9's Avatar
Have you considered going digital. A DS1802 digital pot . . .
Yes. That is the obvious solution. And it looks like the one I'll be forced in to. I've also looked a scheme published in EDN that lets you control as many CAT1113's as you like with a mechanical pot. I'm more comfortable (old fashioned) with a knob I can twist. The idea should work with the Maxim device as well.
I may go this way although the conceptual concept of decent quality ganged pot at a reasonable price (eliminates DACT!) still appeals to me. Rationally, the noise and diostortion figures for both of the units mentioned are quite low, but irrationally I like the passive aspect of tradition.
Old 18th October 2004, 11:04 PM   #6
dnsey is offline dnsey  United Kingdom
How about these?
http://rswww.com/cgi-bin/bv/browse/M...stockNo=393914
Old 18th October 2004, 11:31 PM   #7
sam9's Avatar
Those are certainly along the right lines. 15,000 cycles puts them somewhere between a trim pot but not in the 100,000 cyle bracket of a long service life item. Still it's the right idea. I would just need a small retangular rod that would slip through a row of them.
Definatly someting to try out. Hopefully, shipping cost isn't too bad.
Old 18th October 2004, 11:36 PM   #8
dangus is offline dangus  Canada
...or this VCA: http://www.analog.com/en/prod/0,2877,SSM2018,00.html
Old 18th October 2004, 11:41 PM   #9
My experience with stackable pots is that there's a great deal of play between the shaft and the collet inside the pot. When you turn the shaft, there's a lag of several degrees before the wiper begins to turn. Once you get several of these going together, you cannot guarantee that they will track together. How many dB this might work out to in practice, I couldn't say--I got so depressed about the sloppy mechanical aspect that I got rid of the pots; didn't test them.
Sad, but true.
With luck the pots available today have tighter mechanical tolerances.
Grey
Which value of a potentiometer Alfetta87 Tubes / Valves 9 29th April 2008 12:56 PM
LED potentiometer ralf Pass Labs 20 19th October 2006 05:37 PM
potentiometer log? audiofan Solid State 1 15th May 2006 03:32 PM
Looking for potentiometer paulc Class D 6 3rd February 2006 11:57 PM
Best Value of Potentiometer for T-Amp? HolyGhostFire20 Class D 0 3rd January 2006 10:39 PM
Page generated in 0.09774 seconds (78.46% PHP - 21.54% MySQL) with 10 queries
