| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi folks,
I'm serching for a circuit to convert 9vDC to 48v DC for a mic that needs phantom power. Sennheiser sells an adapter like this,but it's expensive, so I'd like to build one myself. Any information on this is apreciated Tks. Ric |
#2 |
You should look for either a charge pump(SwitchingRegulators) or DC-DC converter.
DC-DC converter are costly. A good start could be a look at National semiconductor web site for SwitchingRegulators (step-up) . www.national.com. you can also search Digikey site |
#3 |
Possible a dumb answer but couldn't you just use 5 batteries?
#4 |
here's a lot of info on phantom power:
http://www.hut.fi/Misc/Electronics/c..._powering.html if you have a wall-wart which delivers AC you can use a voltage multiplier (tripler, quadrupler, whatever) -- this will be quieter than a switcher -- you can regulate 48V with a LM317HV or a TL783 (which will go to 125V) |
#5 |
have a look at mpja.com
surplus site w lots of dc dc converters otherwise oscillator driving multiple stages of voltage doubler those keywords should find a cct
intentionally blank |
#6 |
5 batteries is an option, but since the microphone only needs 2 ma of current at 48V I thought that if the circut is not very complex, it could end up being more compact that a set of 5 batteries.
Weight is another problem. This microphone feeds a camcorder in a Steady cam mount, so weight is of outmost concern. cheers Ric PD: tks for the links, folks. |
#7 |
almost all electret mikes (I suppose that's what you've got since it needs only 2mA) work with smaller voltages. Try yours with two 9V block batteries and, say, 2k2 1% resistors. Also, you might want to bypass batteries with small block caps. Regards, Milan |
#8 |
I do not have that luck, Moamps. The mic is a Sennheiser MK60, a beautiful shotgun that needs 48 V +_ 4V according to the manufacturer.
tks anyway. Ric |
#9 |
I suppose u could build an SMPSU using National's line of switchers...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#10 |
use a MAX1771. It's not the latest/greatest, but will work, has a free sample, and come in an 8-pin DIP package.
| Switching 230 Volt Transformer to 120 Volt | OMNIFEX | Parts | 10 | 6th April 2008 04:34 PM |
| 12 volt subwoofer amp? | roundel325 | Class D | 5 | 11th December 2006 04:18 AM |
| Can I use-35-0-35 volt DC for Leach Amp? | Wynand | Solid State | 9 | 11th August 2005 07:24 AM |
| Volt in a TL | BlackCatSound | Multi-Way | 24 | 1st November 2004 07:29 AM |
| 12 volt DC to 9 volt AC | eRiCdWoNg | Parts | 10 | 18th April 2004 01:52 PM |
| Page generated in 0.09822 seconds (76.45% PHP - 23.55% MySQL) with 10 queries |
