| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Account Disabled
I'm using capacitors in series for higher voltage. I noticed that one of the capacitors was being overvoltaged and it turned out that an equalizing resistor was not soldered well. To avoid this in the future, I want to use LED indicators on each cap so that I can tell if everything is OK with a quick look inside the case. Can someone suggest how I can make it so that a green LED will be on when voltage across the cap is above 300 V and a red one when above 400 V? Since I need a total of 16 indicators, I need the smallest part count circuit that will do this. Any ideas?
#2 |
Zener in series with resistor and LED, but neon lights stacked to 500V or so would do better. With a current limiting resistor of course...
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 |
What current are the equalising resistors carrying? An LED in series with each will glow if there's 0.5-30mA and show if the resistors are working.
| what is the difference between silver mica capacitors and ceramic capacitors ?? | prorms | Solid State | 1 | 6th May 2008 12:38 PM |
| Continental Capacitors' "Type-A" oil-filled capacitors? | radical | Parts | 0 | 21st October 2004 08:39 PM |
| Oil capacitors | Praudio | Swap Meet | 3 | 7th October 2003 03:00 AM |
| capacitors: panasonic FC vs elna RJH vs rubycon ZA capacitors | costiss | Parts | 11 | 30th January 2003 09:32 PM |
| differences between computer grade capacitors and small can capacitors | LBHajdu | Pass Labs | 0 | 22nd February 2002 01:29 AM |
| Page generated in 0.05871 seconds (75.46% PHP - 24.54% MySQL) with 10 queries |
