| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have a problem to make it work: I made a monostable using 555. Is it possible using on/off switch instead of push button to trigger it via pin 2? What I want is: when I turn the switch on (high=+Vcc), it should not trigger the 555 but when I turn the switch off (low), it will trigger the 555 and makes pin 3 high at certain time before goes back to low (depend on C and R). thank you in advance for your help. |
#2 |
Look at page 7 of this:
http://www.farnell.com/datasheets/6604.pdf That should suit your requirements. |
#3 |
thank's BlackcatSound for your link, I will try it. anyway, I found another solution before I read your reply from this site: http://home.cogeco.ca/~rpaisley4/LM555.html look at: menu #20 circuit #2 It's work. see you. |
| mtx amp problem [[help!!]] | fuzzypinkhat45 | Car Audio | 3 | 8th July 2008 05:34 AM |
| CDM 2/29 Problem – HELP! | Bassivus | Digital Source | 29 | 23rd December 2007 10:00 AM |
| FRD/ZMA Problem | Twisted85 | Multi-Way | 5 | 4th December 2006 01:19 PM |
| p3a problem | MaXiZ | Solid State | 17 | 16th July 2005 07:14 AM |
| Page generated in 0.07261 seconds (71.20% PHP - 28.80% MySQL) with 10 queries |
