| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
HI to you all !
As a new member I'm kindly askin for your help. I need urgently the schematic for this Denon POA-6600A beast. Anyone of you that has it and would be so kind and email it to me ??? Or do you know someone that knows someone that might have it ???? I'm desperate... You would probably save by upcoming big bithday party - at this moment I have only one low-range amp and my DALI speakers crossover is at about 1KHz so I loose very much of the stereo image as well as from maximum loudness... I'm confident I can fix this amp myself, but not without your kind help and getting a schematic. The amp is producing a constant negative voltage at the output and the protection relay is working as it should. The outputvoltage is 2,5 volts less than the negative rail so it seems that the output and drive transistors are ok... Your help is more than appreciated Sinverely, Christian |
#2 |
Thank's to Lyra that helped me with the schematic. I now have the amp up and running again!!!
Great forum, great members !!! |
| Denon PMA1560 schematic? | roger-k | Solid State | 9 | 4th October 2010 09:27 PM |
| denon schematic?? | rtate | Digital Source | 2 | 10th June 2008 07:42 PM |
| Denon DCM-280/380 schematic | JoeyDD | Digital Source | 0 | 3rd November 2005 01:22 AM |
| Need schematic for Denon DCD 425 | mig-ru | Digital Source | 1 | 24th August 2005 06:58 PM |
| Schematic Denon POA-800 | roibm | Solid State | 3 | 20th January 2004 11:47 PM |
| Page generated in 0.06513 seconds (68.45% PHP - 31.55% MySQL) with 10 queries |
