Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th October 2004, 07:21 PM   #1
DIAR is offline DIAR  Finland
DIAR's Avatar
Unhappy Overwhelming difficulties with regulators, please help!
I have two problems whitch are probably easy to solve.
1st problem LM317
I'm trying to replace CD player's LM7805 regulator with simple LM317 regulator circuit:
I used 240 ohms for R1 and 750 ohms for R2.
The pin order for LM7805 (in, out, gnd) and LM317 (adj, out, in) is different.
I connected the pins and resistors like this:
http://kotiweb.kotiportti.fi/audiovi.../kytkenta2.jpg
I tested the regulator with 1 kohm and 47 ohm load and I had a 9 volt battery as a powersupply. The voltage was first 5.8 and started getting higher. I had a 4,7 uF cap between putput and ground. No other caps.
2nd problem LM7808
I'm building a simple regulator for Tentlabs XO clock. I used this PCB:
http://kotiweb.kotiportti.fi/audiovi...piirilevy3.gif
Again the voltage was first over 5 V (should be 3.3 V) and started getting higher every second.
I've tried everything and searched half the internet for a solution. You people are pretty much my last hope. Please help !!
Old 5th October 2004, 07:25 PM   #2
chris ma's Avatar
Normally I see a diode of some sort to prevent the regulator get into trouble in these sort of circuits.. can you post the entire schematic ?
Chris
Old 5th October 2004, 07:49 PM   #3
DIAR's Avatar
LM317 is going to be installed to replace this:
I add nothing else but the regulator with the two resistors (no diode). I haven't tried it yet in the cd player.
LM7808 is connected to that circuit. There is nothing else in it. PSU is going to be unregulared 16 V DC.
Old 7th October 2004, 08:48 AM   #4
godzich is offline godzich  Finland
godzich's Avatar
LM317 oscillates easily if you have capacitance at the output but not at the input. Connect a small ceramic 0.1uF capacitor fron the input pin to the same point where the voltage setting resistor is connected to ground - keep wires short. This should fix it is the problem is due to oscillation. Use an oscilloscope to verify. It might be that you already have there a cap - but I was not able to tell because your spelling putput spelling mistake
Christian
Old 7th October 2004, 12:54 PM   #5
DIAR's Avatar
Countryman to the rescue.
I designed this module last night. There are 2000 uF caps in the power supply and 1000 uF after the regulator. Unfortunately I don't have an oscilloscope (I know it's a basic household appliance) but I might know a few people who might be able to help...
http://kotiweb.kotiportti.fi/audiovi...ad/moduuli.png
Old 12th October 2004, 04:34 AM   #6
Default LM 317...
Refer to the datasheet on www.national.com
You will find there is a cap to ground from adj pin.
Use the given formula and calculate the value of R2.
If you connect a larger cap at the output then the input, the output cap tends to supply voltage to the output of the regulator when the input voltage is switched off and damages the regulator
Every aspect and variants of the application exist at national website.
I suspect you are trying to replace 7805L with LM317T
Also fix a heatsink since your i/p voltage is quite high.
Gajanan Phadte
Old 14th October 2004, 07:20 AM   #7
tekman is offline tekman  Germany
2 DIAR: To probelm #2: It's hard to read the circuit for me just by seeing the board, and no shcematic.
AFAIK the 7808, the mounting in the board should be the following: metal cooling fin should be facing the 100 uF caps (if the metal is facing to the "outer" border of the printed circuit board, IN and OUT are reversed forthe 7808 -- this might be the reason for the voltage change.
Let us know how things turn out, pls.
Old 14th October 2004, 09:59 AM   #8
Circlotron's Avatar
Default Re: LM 317...
Yes. Across R2. 1uF is a good value to start with. It could indeed be oscillating.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 14th October 2004, 11:43 AM   #9
DIAR's Avatar
LM7808 schematic can be seen here:
http://www.tentlabs.com/ProductEntities/XO/XO.html
I noticed the wrong pin order. I made the pcb but I haven't tested it yet.
http://kotiweb.kotiportti.fi/audiovi...irilevy_V2.jpg
I assembled LM317 regulator but I haven't tested it yet.
http://kotiweb.kotiportti.fi/audiovi...i/valmis_1.jpg
The PCB layout is attached.
I really hope they work this time. I have burned several regulators already
Old 14th October 2004, 11:58 AM   #10
2 DIAR,
thank you for the website link.
Well, I can't understand why they do so much efforts to propose this circuit for genrating the Supply voltage for the XO:
Datasheet says 5 V +/- 5 %.
So you can simply use 1 7805 regulator, 100uF at input, 10 uF at output -- voila - 5 V with 3 parts.
The original circuit is much more effort, and leaves you with a little bit lower noise level on the +5V rail -- but that's not relvant for the XO.
BTW: If you "burn" the regulator IC's than it is very very shure that there is a problem with your pinout on the board. If I run into this, I let a freind look at the board -- people that are not involved in the project see faults in secounds where I fail for days not seeing these.
Difficulties with DC/DC converter 12V to +/-40V, 8 amps vena2a Power Supplies 15 19th April 2009 10:03 PM
Difficulties with SEPIC converter Bootstrapper Power Supplies 13 22nd August 2008 06:57 PM
citation 12 hum und bias difficulties to adjust leloga Solid State 2 10th March 2007 11:23 AM
PCM2902 difficulties jmar Digital Source 7 13th January 2006 09:07 PM
Page generated in 0.11797 seconds (81.65% PHP - 18.35% MySQL) with 11 queries
