Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th October 2004, 02:31 AM   #1
chris ma's Avatar
Default Tektronix 2213A what to do next
Hello there,
Now that I bought this 60MHz Oscilloscope from a sidewalk sale. No idea it will work or not, it has no probes, no manual, however there is one homebrew lead RG59 when I touch it then it show this. I guess it(CRT) is working some what and bought the thing as is with cdn$500 cash no hope of refund or return just a gamble instinct as from reading the forum a scope is a must have item/tool for diyers. Hope it is worth as the saler claimed.
So I try to find out what I can do with the scope and what I should avoid using the scope without causing damage to it and myself. I wish there is a WIKI for how to utilize a scope at least for beginners that never use one before...
Chris
Old 5th October 2004, 02:34 AM   #2
chris ma's Avatar
Default Frontage
Tektronix 2213A
Old 5th October 2004, 03:15 AM   #3
ashok's Avatar
Default Basics
Hi Chris,
Check this out.
http://www.tone-lizard.com/Oscilloscopes.htm
Ashok.
AM
Old 5th October 2004, 02:18 PM   #4
chris ma's Avatar
Thanks Ashok!
Nice site you have pointed
Chris
Old 6th October 2004, 04:34 PM   #5
eehobby is offline eehobby  Canada
Default pass/fail test
Try this:
1) Take the RG59 center conductor and stick it in the round hole on the front panel marked "Probe Adjust" (on the right side of your first photo, about 2/3 down); you should see a square wave on the screen. Experiment with amplitude, time base, and trigger controls until you know the basics.
2) If the scope passes the above test, buy some used 1X probes, or some adapters and test clips.
3) Invite an Electrical Engineer over for a beer and ask him/her to put it through it's paces (or you could start with this step, since the EE will know a lot about steps 1 and 2).
Old 14th October 2004, 09:08 AM   #6
tekman is offline tekman  Germany
2 chris_ma:
This is a nice scope, very reliable.
You will get more out of it with a proper operating manual:
download here: bama.sbc.edu or faster: bama.edebris.edu.
There is a Tektronix 2213 operating manual for download, whic his 99.9% compatible to the 2213A.
good luck!
Tektronix 2230 or TAS-475 xaudiox Parts 3 8th April 2009 09:57 PM
Tektronix 475 PSU Troubleshooting.......... Gavinator68 Solid State 40 21st September 2008 04:53 PM
How to check for low/high frequecy oscillations with a Tektronix 2213A chris ma Solid State 9 24th May 2008 02:26 AM
Tektronix 916 DVM ANTHONY2181 Swap Meet 0 6th October 2004 11:44 AM
Page generated in 0.09265 seconds (75.78% PHP - 24.22% MySQL) with 11 queries
