Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd October 2004, 04:31 AM   #1
AX816 is offline AX816  Romania
Send a message via MSN to AX816 Send a message via Yahoo to AX816
Default Is the Stk 3042II a preamp or an amp?
I've got from an old friend an Stk 3042II.But when i searched to see from wich family does it has been born...nothing conclusive. In this link http://www.donberg.ie/descript/s/stk302ii.htm
is a preamp for wich i even found a schematic...But on Sanyo's homepage it is found as an amplifier ranged from 40W to 60W.
All this info is at least confusing ...Does anyone know a 'secure' schematic for this HIC ?
Old 3rd October 2004, 04:00 PM   #2
Bill Fitzpatrick's Avatar
data sheet here
http://audiolabga.com/pdf/STK3042II.pdf
Old 3rd October 2004, 05:18 PM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Interesting chip. It is a stereo voltage amplifier that can be made into a power amp by adding an output stage. In other words, it is the differential input stage, the voltage amplifier and the provision to add the quiescent bias circuit (between 5/6 or 10/11).
I wonder how the dynamic performance would be?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Solid State 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
Page generated in 0.06636 seconds (73.01% PHP - 26.99% MySQL) with 10 queries
