Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 24th September 2004, 01:11 PM   #1
Default Microwave transformer
Can someone confirm the HV section of this transformer?
http://diyaudio.com/forums/showthrea...306&highlight=
I've searched under "microwave", and "microwave transformer" and haven't found my answer. I am currently reading some pages on rewinding as I found a post with about 20 or so links.
If anyone can answer any of the questions I have on the original post that would be great too.
I checked the rules and didn't see anything on cross posting treads, so I hope this is alright.
Steve
Old 24th September 2004, 04:25 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
What appears to be 52V is supposed to be around 1200VAC. Wound of 24 to 28AWG wire (kinda thin; about 2000 turns). Most of the time, all connections are by 1/4" spade terminals (or whatever the metric equivalent is), possibly on wires instead of spades mounted on the windings, as you appear to have.
The winding (s1 I think you indicated), which is just three turns around the top, is for the magnetron filament. 3.15V at around 30A. The remaining winding (heavy wire, about 150-200 turns) is the primary.
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 24th September 2004, 04:44 PM   #3
For some reason I thought that was the HV secondary. The one I indicated as s1 & s3 measures 3.5 v. I didn't try before because my DMM is 500v ac max. I guess I'm lucky I didn't burn it up. Maybe the transformer went out? I salvaged it from a broken MW. So could I just grind off the top section I indicated as 52v and then just multiply the turns I have across s1-s3 by about 14 or so and rewind the top section? Or will it be different because it's wound on the core vs. around the primary. I think I could rewind the top without disassembly with so few turns. The TF hums slightly too, if your within a foot or so. Would taking it apart, recoating and reassembling it help?
Steve
Old 24th September 2004, 07:06 PM   #4
djmiddelkoop's Avatar
I have 3 magnetron transformers and the secondary outputs a very dangerous 2000Vac at rated input voltage.
Don't try to measure without appropriate equipment !
For the rest the windings are described as by Sch3mat1c.
Dick.
Music is the best F.Z.
Old 24th September 2004, 09:09 PM   #5
I made sure I was at the end of a 10 ft cord when I plugged it in. I just fid it weird that the HV winding was only putting out 52 v.
Microwave 'ultratweeters' morbo Multi-Way 40 27th April 2005 02:45 AM
Rewinding Microwave Transformer 6502dude Power Supplies 5 3rd April 2005 04:06 PM
Microwave transformer as choke? leadbelly Parts 32 13th March 2005 07:26 AM
microwave transformer for PSu slackerbob Solid State 4 11th January 2004 05:58 PM
Page generated in 0.07768 seconds (72.32% PHP - 27.68% MySQL) with 10 queries
