| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
Warp Engineer
On Holiday
96% tin, 3.5% silver and 0.5% copper would be my preference for lead free solder.
- Dan |
#12 |
who has had a problem with solder that has aged...
I guess I'm just a NQO...non qualified operator.. Seriously, I have been in situations where the solder I was using was old, and didn't work at all. I blame the flux for that, lead oxide second culprit...when I tried going further into the roll, like two or three layers in, it still didn't work. Making me blame the components, till I switch to a new roll of solder, then it works like a charm.. Also have seen plumbing flux age, raising holy heck..again, switching to new can of same brand fixed it.. And, don't get me started about those nickel plated anythings...once they age a bit, major headaches, especially if you try to use R core tin silver..you might as well be using a hammer.. Cheers, John |
#13 |
No, John, you're not the only one who has a preference for fresh solder over the aged kind. I do a fair bit of production and production overseeing, and it certainly appears to me that new solder is easier to work with (flows faster and wets better for less heat input) and delivers nicer-looking results, especially when doing hand-soldering of SMD components. You can still do a good job with older solder, but it requires more care and concentration.
I also like to replace the solder iron tips at fairly regular intervals - for similar reasons. It is simply easier to make nice-looking joints when doing fine soldering if the tip is not too old. regards, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com |
| Lead Free Solder Recommendations and Procedures | mhconley | Construction Tips | 7 | 19th June 2009 07:04 AM |
| lead-free solder: shiny when liquid but suddenly it turned dull when it solidified | jarthel | Parts | 3 | 5th August 2006 07:52 PM |
| Lead free solder | bigwill | Equipment & Tools | 11 | 12th May 2005 06:30 AM |
| Lead free solder | djmiddelkoop | Parts | 13 | 24th January 2004 06:52 PM |
| Page generated in 0.06279 seconds (74.46% PHP - 25.54% MySQL) with 10 queries |
