Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd September 2004, 03:15 PM   #1
Question Bench Supply
a quick question, if I may?
I have seen a bench supply with 0-30V output at 3A. Both V and I are adjustable. Output socket are "- " "GND" and "+" in that order.
Daft question , but could I use this as a split power supply to test a module I have, or is it only good for supplying, say +12V (as opposed to +-12V)?
Thanking you for your advice!!
Jon
Old 22nd September 2004, 04:59 PM   #2
johnnyx is offline johnnyx  United Kingdom
It sounds like this is a single output power supply. The seperate "gnd" terminal is brought out so that either + or - can be grounded, depending on what is required. So you cann't use it for +-12v.
Old 22nd September 2004, 05:08 PM   #3
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
if you saw it in a store, you could ask them to test it if it puts out dual outputs (+/-) or only single.
it may be possible that it could put out about +/-30V.
Old 22nd September 2004, 05:15 PM   #4
jackinnj's Avatar
Default Re: Bench Supply
Jon
For some regulated supplies the GND is attached to the chasis and the mains ground only, this is the case of some of the Lambda supplies which are used in the Physics lab -- there are two floating supplies, i.e. two "+" and "-".
Old 22nd September 2004, 05:36 PM   #5
Thanks for the replies!
This is an eBay item I have my eye on. An ISO-TECH model. Looks like it is a single output model. I'll have to get back on there to see if I can root out a more appropriately specced model.
Many thanks!!
Jon
Bench supply? agithegreat Power Supplies 4 18th June 2009 12:30 AM
+/- bench supply ideas.. DigitalJunkie Power Supplies 8 3rd January 2007 08:51 PM
My new bench power supply Circlotron Equipment & Tools 7 28th April 2003 04:29 PM
bench power supply jethari Parts 1 14th March 2003 06:31 PM
My bench power supply.. deepanger Solid State 71 18th February 2003 08:56 PM
Page generated in 0.06884 seconds (84.54% PHP - 15.46% MySQL) with 10 queries
