| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#51 |
I use them in my present project and I find them excellent. Very low noise and distortion.
If my 15 V DC were the radius of the Earth, Mount Everest would be 1 meter tall. |
#52 |
I'm like DigitalJunkie. I like the TL072, plus the LF353, because they give more 'meat' on the musical bones than the more 'modern' replacements. The AD712 seems a good 'compromise' between old school and new.
#53 |
Hi Peteramp!
I like to try new or old Op Amps too! So I must ask where are you using tloxxxx amps and what type power supply. type caps ,and compensation,Did you hear these or Test them ? type amps and speakers,source? I am using a middle of the road(HD280Pro's)headphones to test op amps they don't color as much as my speakers and I set the spectrum flat before I listen and sound differences do show up,lol. Not putting you on the spot here,ok? Just after better sound,lol. Thanks!!!!!!!!!! |
#54 |
Hi noSmoking,
I've used TL0XX's in things such as Audio Research SP-9, Marantz CD63 cdp, and they ALWAYS give an unfailingly sweet sound. One thing is for sure, it's NS (National Semiconductor) types that always sound best.TI (Texas Instruments), ST etc are mainly thinner and harder sounding. I have very revealing 4 way 'speakers (hand made), and changes like substituting op amps, wire, caps are easily discernible. I'm awaiting some 825's with so-called 'pass transistors', I'm not fussed if they will improve on what's already in, but I do like to try a variety of combo's, as if you don't, you will never know. Now, did anybody order a drink...is that with one ice cube or two, fancy or non fancy glass (tubegod, are you there)? Bottoms up, peteramp Last edited by peteramp; 12th October 2011 at 02:21 AM. |
#55 |
Hi peteramp.
I haven't tried tlo but I have a bunch of tlo 71 and 72's that I will try, I have a box that has 2 of most op amps in it. I have found some opamps sound better in different circuits,so I change out until I find the ones I like, I bought a dac and use the dips on it to test most opamps ,it gives a good indication of what the end result is, Less ice in that drink,more room for booze,lol. |
#56 |
Hi noSmoking,
love your work (regarding the drink ). Don't forget those LF353's if you can get your hands on them! If I have anything interesting to post on those AD825's with mods., I'll let you know. cheers, peteramp |
#57 |
The tl084 is a good quad op amp. I have had trouble with some op amps inverting the output on loud passages but the tl084 works fine.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#58 |
Thoughts about:
MC33078 MC33178 LS204 LF442 Intented do make a onboard (2 x 9v battery)bassguitar preamp/eq . |
| advice for audio card OpAmps | neong | Parts | 2 | 20th October 2008 07:16 AM |
| JRC opamps | browser | Solid State | 3 | 30th July 2008 08:58 AM |
| FS: LME49720 Audio OpAmps | zener_diode | Swap Meet | 2 | 17th February 2008 04:13 PM |
| Military opamps in audio | Uchi Deshi | Chip Amps | 1 | 3rd August 2006 05:43 PM |
| FS: Power Chip OpAmps and other OpAmps & D to A Converter | dtm1962 | Swap Meet | 4 | 12th January 2006 10:07 PM |
| Page generated in 0.09679 seconds (78.26% PHP - 21.74% MySQL) with 11 queries |
