Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th September 2004, 05:56 PM   #31
Prune is offline Prune  Canada
Account Disabled
And what about this one:
http://www.diyaudio.com/forums/attac...&postid=328821
I don't understand why the capacitors are in parallel here...
And this one:
http://www.psaudio.com/products/images/306_1.jpg
How can it work with such tiny caps?
Old 17th September 2004, 06:55 PM   #32
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
I doubt the designer does, either. Note that any cap I'm aware of can withstand 3V or less in either direction... it easily reforms under such conditions. There's so little voltage, faliure isn't going to happen either (don't quote me on that, everything dies (to quote Type O Negative) eventually).
The formula to find capacitance has nothing to do with decibels, just ohm's law, capacitive reactance, load current and the maximum tolerated voltage drop.
And this one:
Probably in parallel, to shunt rectifier hash.
Tim
Seven Transistor Labs
Projects and Resources
Old 17th September 2004, 07:07 PM   #33
Account Disabled
Diodes do not block DC by themselves, you need large caps. In a thread where the photo (commercial product) was mentioned, the maker said the capacitors couple the AC waveform near the zero-crossing where the diodes do not conduct. Again, I don't see how small caps can do that. Maybe I'll build a transformer model in the simulation instead of using a resistive load and see if it changes anything. As for the first circuit, it's also from a commercial product, an amplifier that's supposed to be very reliable. But I'm wondering if someone messed up the schematic.
Ess AMT polarity? Help promitheus Planars & Exotics 1 13th July 2007 09:52 PM
Hi-Vi B3N polarity Gollum Multi-Way 5 5th July 2007 05:58 PM
GE 97F cap polarity ??? maynardg Tubes / Valves 0 3rd February 2007 09:20 PM
LED polarity guitargully Solid State 4 12th January 2004 04:14 AM
Copyright ©1999-2013 diyAudio
