Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th September 2004, 03:30 PM   #21
jan.didden's Avatar
Originally posted by Geek
The mains DC is from an asymmetrical waveform due to incorrect power distrobution, loads or interference on the lines. Because of that, the circuit is, IMO, useless.
Funny circuit. I would think it actually CREATES offset (low at that) what with the diodes which are probably not matched. The caps across the diodes are pretty useless, no? the waveform across the diodes looks very much a square wave with 1.2V amplitude or so. That means that the voltage across the transformer, which is the mains minus the voltage across the diodes, looks like sine with the middle part missing, that's disturbingly similar to good old xover distortion waveform. Why would that stop a toroid from buzzing?
Strange.
Jan Didden
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Old 16th September 2004, 03:37 PM   #22
Prune is offline Prune  Canada
Account Disabled
I ran this in LTSpice. If you simulate it, the sine wave goes through just fine. Without the capacitor that does not happen. The cap lets through part of the waveform until the diodes begin conducting, omit it and the waves get distorted.
Old 17th September 2004, 11:50 AM   #23
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
As long as the reactance of each is well under the resistance of the load (so it produces less than a volt AC drop), it won't matter. As a plus, you can also use 6.3V caps, odd as it may seem on a 120V line.
The L+C is a filter, even if it did oscillate (read: ring due to an external source) it would be at some random frequency, depending on leakage inductance.
Tim
Seven Transistor Labs
Projects and Resources
Old 17th September 2004, 02:35 PM   #24
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by MikeB
Hmm, about the mainsdcblocker.gif , i might be paranoid, but doesn't
the combination of L1/L2 + C2/C3 form a nice oscillator ? Aren't
resistors in series with C2/3 a must ?
Mike
If you have a LC-filter you can always get a resonance, but not an oscillator! You must have an active element for this. But nevertheless the filter designer must know how much Q the circuits has in order to determine the filter characteristics.
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 17th September 2004, 02:37 PM   #25
peranders's Avatar
The diodes are for inrush current transients. If the DC level is more than 0.6 V you must either change the caps to a bigger value or add more diodes in series or use Zeners.
The cap values is determined by the max steady state current. If one diode is needed the max voltage drop over the cap is 0.5 - 0.6 V.
4 A, 50 Hz, 0.6 V max = 21221 uF
Old 17th September 2004, 02:48 PM   #26
MikeB is offline MikeB  Germany
MikeB's Avatar
Yes, that's what i've meant. Anytime a spike comes in, the LC is
pushed, and could create a HF-ringing. I am missing a lot of english
words for these things. In german the combination of L & C is called
"Schwingkreis", this is normally used for AM-receiving.
My problem with the filter is, that these Spikes appear often in the mains.
Mike
Old 17th September 2004, 03:21 PM   #27
Sch3mat1c's Avatar
Any tank can be considered an oscillator (an "oscillating system", pendulum, spring and weight, inductor and capacitor, etc.), but us electronics-heads take it to mean an active device.
Tim
Old 17th September 2004, 04:06 PM   #28
Account Disabled
Peranders, what's the formula you used for that calculation?
Old 17th September 2004, 04:20 PM   #29
dnsey is offline dnsey  United Kingdom
My question as to how to match capacitors remains unanswered
Put them in opposite arms of an AC bridge (easily thrown together if you don't have one).
Old 17th September 2004, 05:20 PM   #30
Account Disabled
Peranders, did you solve for the -3 dB corner, as that's what it looks like? Don't you think that the -3 Db is a rather arbitrary choice? Why not -1 dB or -5 dB instead?
I wonder if the distortion added by insufficiently large caps may be worse than a little DC.
Ess AMT polarity? Help promitheus Planars & Exotics 1 13th July 2007 09:52 PM
Hi-Vi B3N polarity Gollum Multi-Way 5 5th July 2007 05:58 PM
GE 97F cap polarity ??? maynardg Tubes / Valves 0 3rd February 2007 09:20 PM
LED polarity guitargully Solid State 4 12th January 2004 04:14 AM
Copyright ©1999-2013 diyAudio
