Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th September 2004, 05:56 PM   #1
steenoe is offline steenoe  Denmark
steenoe's Avatar
Default DIY "Anodizing"
Here is a simple way of making a nice aluminium surface.
The method is widely used for treating the surface on
aluboats, and is remarkably strong against oxydation.
It results in a silky smooth surface, that is very easy to
keep clean and nice. Here we go:
The piece of alu must firstly be brushed so the surface is
absolutely smooth and homogen to look at. The easiest
way to "brush" is actually with sandingpaper. You need
good quality sandingpaper for this. The cheap stuff won't do.
Also it has to be a little coarser than you would think.
120 grid is a good starting point. You have to be very
meticulous at this point. Your sanding strokes must
be even, in the hole length of your piece. The surface will be a little rough, but this will go in the next step.
A serious warning: You really need a pair of rubbergloves for the
next step, as this stuff eats your skin for breakfast! No kidding.
Dont get it on bare skin or into your eyes.
Your piece of alu must be washed with a solution of NaOH
dissolved in water. I have used about 3 good spoonfull's
for 2 cups of water.(NaOH= Caustic soda). It is done in much the same way as when sanding, only I use a Regular kitchen sponge
for the job. The rough green side of it . Just soak it often, as you stroke back and forth. Keep stroking for about 5 minutes.
The solution is not allowed to dry up on the piece of alu, as this
will get very stained. When done, rinse the piece very well
under tap water. Dry the piece and you are done!
If you are not satisfied with the result, work at it again.
There you have it. It is not excactly Anodizing, but it looks
very good. In all cases it looks way better than raw alu
I attached a pic of my stereo, the preamp (BosoZ) is fitted with a faceplate made in this manner. It is about a year old now and looks like the day it was made.
Hope this will be useful for all you DIY'ers.
Steen.
Old 14th September 2004, 05:59 PM   #2
SY's Avatar
I can't stress your safety warning enough- sodium hydroxide will turn you into soap and can be deadly if not handled properly. Thick, alkali-resistant gloves, safety glasses, and proper chemical disposal are MANDATORY.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 14th September 2004, 08:54 PM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Yep, neutralize with vinegar...
FYI, this process is NOT anodizing, AT ALL. It is chemical etching of the aluminum.
Can also be done by soaking in a tub of lye solution, no rubbing or sponge needed.
BTW, I'm suprised the average sponge isn't eaten alive by lye..?
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Old 14th September 2004, 09:07 PM   #4
SY's Avatar
Depends on whether or not it's a natural sponge. Some synthetics do very well in alkaline solutions. Natural sponges do less well.
There's a spongeworthy joke in there somewhere for all you Seinfeld fans.
Old 14th September 2004, 10:15 PM   #5
Geek's Avatar
For some black (well, black/blue) anodizing, try a tube of "Cold gun blue" from a gun store. It's original use is for "blueing" of untreated (like, where you sanded the rust off) spots on your guns, but works on many other metals.
The warnings on the tube are minimal, but it is selenium based and should be treated as any other selenium/asbestos product....well ventilated room, rubber gloves, goggles and dispose of rags in an approved way.
Old 15th September 2004, 03:35 PM   #6
steenoe's Avatar
I took some closeup pic's of the surface as it looks after
having had this treatment. The "Spongeway" is used
because you can make just a small amount of the solution.
This is more environmentally friendly.
Steen.
Old 15th September 2004, 03:36 PM   #7
steenoe's Avatar
And still closer
Old 15th September 2004, 03:42 PM   #8
steenoe's Avatar
And the sponge.
I am sure your girlfriend would have hoped you knew that one.
From the kitchen that is.....
Old 15th September 2004, 10:34 PM   #9
adalin is offline adalin  Sweden
adalin's Avatar
Nice..
I will experiment a little I think... Might just be the right treatment for my current project...
Tubes 4 ever
Old 15th September 2004, 10:57 PM   #10
Bill Fitzpatrick's Avatar
what is the source of those flaws on the panel?
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
Fostex "rated input" and "music power" hugz Full Range 12 16th March 2006 04:33 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.11153 seconds (85.68% PHP - 14.32% MySQL) with 11 queries
