Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th September 2004, 09:55 AM   #1
polsol is offline polsol  South Africa
Default High Voltage/Current Regulators
Any suggestions for alternative voltage regulators to the NS LM 338K?
The 338 is a pretty expensive chip when compared to something like the LM317. Is there no way of using say a BJT in parallel to a 317 to boost the current and voltage of the later?
Any other suggestions for a regulator to be used in a home made PSU with say a 300VA 35-0-35 transformer?
The PSU is to be used for testing power amps.
Tony M
Old 13th September 2004, 11:18 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Exactly what you ask for is in the 317 data sheet.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 13th September 2004, 12:43 PM   #3
Thanks, I have an old data sheet but will download the newer one. My data sheet suggest using parallel 317's with an opamp servo but would prefer to use one 317 with a single BJT.
Will rdownload and ead tonight when I get home.
Tony M
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
High Voltage negative regulators Tweeker Tubes / Valves 3 27th February 2009 12:14 AM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
parallel voltage regulators to increase current? troystg Solid State 21 22nd May 2004 07:35 AM
High voltage regulators eeka chu Digital Source 5 29th April 2004 10:20 PM
Page generated in 0.07095 seconds (69.86% PHP - 30.14% MySQL) with 10 queries
