Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th September 2004, 06:41 AM   #1
Prune is offline Prune  Canada
Account Disabled
Default Load sense
I need a circuit that will sense whether a sufficient load is connected to an HV, high power supply (brute force filtering), so it can turn power relay off if load is too low (both to avoid the rising voltage, and as a form of protection so there's no HV on the output power cable when it's disconnected). Any suggestions how to do this?
Old 13th September 2004, 06:50 AM   #2
Geek's Avatar
That's what a "bleeder resistor" takes care of.
Old 13th September 2004, 06:53 AM   #3
Account Disabled
That doesn't help with my second problem: when the HV power cable is unplugged from the amplifier, I want power off -- like a safety interlock. For the overvoltage issue, I'd have to bleed something like 10%, or about 100 W -- that's nasty.
Old 13th September 2004, 07:19 AM   #4
Geek's Avatar
What kind of HV and current we talking about? A HAM radio 2KW amp supply with 3,300V @ 1.5 amps usually require that much [100W].
I'll do the math for ya
Old 13th September 2004, 07:59 AM   #5
Account Disabled
Less than that. The microwave oven transformer I have is 2100 VAC RMS and about 700 mA. I don't need all of it. When I rectify and use a what I've got for filtering, CRCLC (82.5 uF, 300 Ohm, 80 uF, about 4 H, 80 uF), the simulator gives me about 2700 V, in my estimated 400 mA load (in practice it's a bit less, about 2600 V). So about 1 KW.
What if I just wind a current sensing coil around the output cable and use it to drive the relay transistors? How do I calculate such a setup?
Old 13th September 2004, 09:06 AM   #6
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Bah. You could use a crowbar relay. When turned on, relay pulls in and opens circuit to a low-ohms resistor. When turned off, relay shorts HV output across resistor.
Running an idle load of 10% is typical. 100W seems like a lot, but then, 1kW is a lot too.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Power load, dummy load (pic) luka Power Supplies 43 9th February 2012 02:50 PM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
Dynamic load line analysis using music and speaker load Michael Koster Tubes / Valves 0 7th March 2008 08:47 PM
TL, does this now make sense? Madmike2 Multi-Way 2 8th May 2005 02:39 PM
Does this make sense ? 00940 Solid State 7 27th March 2004 09:29 PM
Page generated in 0.08109 seconds (72.31% PHP - 27.69% MySQL) with 10 queries
