Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd September 2004, 10:46 AM   #1
Default components identification
Anyone out there ready to help a novice?
3 questions ranging from easy to more advanced, easy first.
1. Electrolytics: If one of the terminals is marked with a stripe with a 0 in it, does that mean its non-polar?
2. Other capacitor (unknown type) marked: A/.1J250
I bought these a while ago for something, think I know what for but the marking is very confusing and I cant find the marking scheme on the net. Translation into plain english please.
3. Chip: SB61L256bs-8 ... Any ideas what it does?
Thanks everyone :-)
Old 3rd September 2004, 11:51 AM   #2
1. Stripe down side of electrolytic means negative terminal, so it is polarised. Non polarised caps usually have no stripe and "NP" on them.
2. Other cap is 0.1uf (100nF) 250V DC rating - probably polyester type.
3. Without doing a search on the number, it is probably a RAM (memory) chip, 256kB 8uS speed, possibly low power version ("L" in number).
Hope this helps
Cheers
Old 3rd September 2004, 01:21 PM   #3
Default Thanks!
Thanks for that Centauri! Very useful info. Second cap was what I hoped it was. Can you explain the coding so I understand better?
Cheers!
Old 3rd September 2004, 03:37 PM   #4
Apex Jr is offline Apex Jr  United States
To add a little on the above post:
The J = 5% ....... K = 10% and M = 20%
A at the beginning is probably the Manufacturer.
Steve @ Apex Jr.
Old 4th September 2004, 04:28 AM   #5
Default Resistors
All this is about two Quad 405-2 s which Im freshening up and modding (as well as a klipsch digital surround processor/preamp). The quads also have some 10 Ohm resistors which get very hot (so hot that the surrounding components are scorched) Im replacing them and moving them further from the board. Are the much bigger, wirewound type noisy in comparison with the ordinary little ones and can they be used in audio applications?
Cheers!
Jumper identification HELP JC Fardo Parts 0 6th May 2009 11:28 AM
Help with Cap identification SVinzant Parts 3 22nd January 2009 12:54 PM
Need identification if possible. es44 Full Range 2 11th September 2008 08:38 AM
Cap brand identification. ChuckT Parts 2 30th July 2003 04:23 PM
Page generated in 0.07666 seconds (70.69% PHP - 29.31% MySQL) with 10 queries
