Transformer experts needed Transformer experts needed - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd September 2004, 07:42 AM   #1
nanonash is offline nanonash  Australia
Default Transformer experts needed
Hello,
Following a previous post about replacing the power transformer of a Phonic mixing desk. I have made some progress but...
Basically I have worked out the schematics, and the power supply section provides -12V, 0V and +12 V
Therefore I bought a 2* 15 V replacement transformer .
My problem is : on the original transformer there are two outputs (which I bielive are 15V each) but there is also a ground (black) wire which is at the center..
the original transformer looks like this:
----- Red (15V?)
----- Black OV ????
----- Blue (-15V?)
Therefore I have 5 outputs but the transformer i bought has only 4 outputs (2 coils at the secondary)
I'm really puzzle about this black wire... what should I do ? this wire is connected to the general 0V ground (chassis).
Btw there is almost zero ohm between this black wire and any of the blue wires but infinity with the red wires (but the secondary of this transformer could be bad)
Did I buy the wrong transformer ?
thanks for your help
Nano
Old 2nd September 2004, 09:28 AM   #2
Centauri is offline Centauri  Australia
I would suspect the black wire is a centre tap for the blue secondary, possibly 15-0-15V. The red wires are probably a separate winding for another supply, possibly to supply higher current for lights/leds or higher voltage for phantom supply.
Have you traced out the circuitry around where the transformer wires connect to the board, and can possibly post a drawing of it?
Cheers
Old 3rd September 2004, 05:38 AM   #3
Thanks for your help.
I have started drawing the schematics.. I will scan them and post them on this thread.
Cheers
Nano
Old 6th September 2004, 06:58 AM   #4
Hi ,
the black wire was indeed a center tap for the blue winding. And the Red was another 12V winding. The mixing desk is now working great.
nano.
Old 6th September 2004, 09:47 AM   #5
Transformer experts neededHide this!Advertise here!
Quad 405 experts needed. audiolabtower Solid State 4 27th February 2009 01:07 PM
Ono/Xono Circuit Experts needed! Barry1 Pass Labs 7 5th March 2008 05:36 PM
Akai reel to reel repair experts needed inside CBRworm Analogue Source 6 3rd November 2007 11:24 PM
FET experts advice needed bostjancek Solid State 4 24th November 2005 01:52 AM
Experts needed: Crazy phase issue with Inverted Gainclone PaulHilgeman Chip Amps 30 20th February 2003 06:06 AM
Copyright ©1999-2017 diyAudio
